ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2015-01-05 11:40] mvaderccgx:ccgx_wireless_ac_sensor [2021-03-20 03:05] (current) guystewart
 ====== Wireless AC Sensor manual ====== ====== Wireless AC Sensor manual ======
 +(discontinued product)
 ===== Introduction ===== ===== Introduction =====
-The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[http://www.victronenergy.com/panel-systems-remote-monitoring/colorcontrol/|Color Control GX]] and the [[https://vrm.victronenergy.com|VRM Portal]]. An installation will have one gatewayand one sensor per phase. The gateway connects to the Color Control via Ethernet, and is the DECT hub for the sensors.+The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[https://www.victronenergy.com/panel-systems-remote-monitoring/colorcontrol|GX device]] and the [[https://vrm.victronenergy.com|VRM Portal]]. An installation will have one gateway per system and one sensor per phase. The gateway connects to the GX device via Ethernet, and is the DECT hub for the sensors. Multiple sensors connect to 1 gateway.
 +Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The GX device will in such case only show the value of the last-read sensor.
 +==== Three phase ====
 +For measuring a three phase system, we recommend to use [[https://www.victronenergy.com/live/system_integration:hub4_grid_parallel#using_the_wired_hub-4_ac_sensor_to_measure_pv_inverter_output|this]] meter instead. Using three single phase meters does not provide true three-phase metering and measurements.
 ===== Required hardware ===== ===== Required hardware =====
Line 15: Line 22:
   * AC adapter   * AC adapter
-{{  :drafts:ccgx:wirelessacsensors_microusb.jpg?direct&200}}Note that instead of powering the Wireless Sensor gateway with the AC adapter, it is also possible to power it from one of the USB ports in the Color Control GX. Purchase a separate male Micro-USB to male USB cable, not available from Victron Energy. Note that, due to CCGX-USBport power limitations, this cannot be combined with also powering a USB-GPS, USB-WiFi or not separately powered USB hub.+{{  :drafts:ccgx:wirelessacsensors_microusb.jpg?direct&200}}Note that instead of powering the Wireless Sensor gateway with the AC adapter, it is also possible to power it from one of the USB ports in the GX device. Purchase a separate male Micro-USB to male USB cable, not available from Victron Energy. Note that, due to GX device-USB port power limitations, this cannot be combined with a USB-GPS, USB-WiFi using a non powered USB hub.
Line 24: Line 31:
   - Disconnect the AC power   - Disconnect the AC power
-  - Connect the gateway to the network using the supplied RJ45 cable. +  - Connect the gateway to the Ethernet/LAN network using the supplied RJ45 cable.
-  - Connect the AC power adapter or the USB cable from the ColorControl GX to the gateway+  - Connect the AC power adapter or the USB cable from the GX device to the gateway
 === Installing the sensor(s) === === Installing the sensor(s) ===
 For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct.
- +{{ :ccgx:quby_gateway_schema.jpg?nolink&850 |}}
-{{  :drafts:ccgx:ac_sensor_schema.jpg?nolink&700x352  }}+
 ===== Gateway and sensor pairing ===== ===== Gateway and sensor pairing =====
Line 56: Line 62:
 |Blinking red |Not yet paired to a gateway | |Blinking red |Not yet paired to a gateway |
 |Both green and red on (no blinking) |Cannot find the gateway. Only shows for a few seconds, after that the led will turn off | |Both green and red on (no blinking) |Cannot find the gateway. Only shows for a few seconds, after that the led will turn off |
-|Alternating red/green |Selected in the Color Control menu, useful for identification |+|Alternating red/green |Selected in the GX device menu, useful for identification |
 |Green on (no blinking) |Gateway found, connecting. This will show only for a few seconds | |Green on (no blinking) |Gateway found, connecting. This will show only for a few seconds |
 |Off |Working OK, connected to the gateway, cannot find gateway or not powered | |Off |Working OK, connected to the gateway, cannot find gateway or not powered |
-===== Configuration on the Color Control =====+===== Configuration on the GX device =====
 ==== Wireless AC sensor menu ==== ==== Wireless AC sensor menu ====
Line 96: Line 102:
 |Relative humidity |0 - 95 |% | |Relative humidity |0 - 95 |% |
-~~DISQUS~~
 +===== DISQUS =====
 +~~DISQUS~~
ccgx/ccgx_wireless_ac_sensor.1420454431.txt.gz · Last modified: 2015-01-05 11:40 by mvader
