ccgx:ccgx_ve_power_setup
ccgx:ccgx_ve_power_setup [2018-03-01 23:26] – [4.1 Remote VEConfigure: Requirements] mvader | ccgx:ccgx_ve_power_setup [2023-05-07 09:53] (current) – mvader | ||
- | VE Power Setup is a Windows application that can be used to: | + | VE Power Setup is a Windows application that can be used for three things: |
- Update the firmware of a VE.Can product connected via USB to your computer (requires a CANUSB adapter, ASS030532000) | - Update the firmware of a VE.Can product connected via USB to your computer (requires a CANUSB adapter, ASS030532000) | ||
- | - Remotely updating firmware of a VE.Can product (requires an internet connected | + | - (deprecated) |
- | - Remotely changing the configuration of VE.Bus system: Remote VEConfigure (requires an internet connected | + | - (deprecated) |
- | To update the firmware of a VE.Can product, its typically most convenient | + | Note that even for updating |
Products which can be firmware updated via its VE.Can port are: | Products which can be firmware updated via its VE.Can port are: | ||
- | * BlueSolar Charger 150/ | + | * BlueSolar Charger 150/ |
- | * BlueSolar Charger 150/85 VE.Can | + | * BlueSolar Charger 150/ |
+ | * All SmartSolar Chargers with VE.Can | ||
* Lynx Shunt VE.Can | * Lynx Shunt VE.Can | ||
* All four Skylla-i Battery Chargers | * All four Skylla-i Battery Chargers | ||
* Skylla-i Remote Control Panel | * Skylla-i Remote Control Panel | ||
+ | * Skylla-IP44 | ||
* All our different VE.Can to VE.Bus/ | * All our different VE.Can to VE.Bus/ | ||
* Ion Control | * Ion Control | ||
Line 28: | Line 31: | ||
Notes: | Notes: | ||
* Remotely updating firmware in VE.Bus products (Inverters, Multis and Quattros) is not possible and will also not become possible. | * Remotely updating firmware in VE.Bus products (Inverters, Multis and Quattros) is not possible and will also not become possible. | ||
+ | * Remotely changing settings is only possible for VE.Bus products. | ||
* Since VE Power Setup version 5.0, the product configuration is preserved during a firmware update. More information in our [[https:// | * Since VE Power Setup version 5.0, the product configuration is preserved during a firmware update. More information in our [[https:// | ||
* Looking for Remote VEConfigure with a " | * Looking for Remote VEConfigure with a " | ||
Line 36: | Line 40: | ||
- Download and install VE Power Setup from our [[https:// | - Download and install VE Power Setup from our [[https:// | ||
- | - Obtain the necessary firmware file on [[https:// | + | - Obtain the necessary firmware file on [[https:// |
- Connect the VE.Can product to the computer, using the [[https:// | - Connect the VE.Can product to the computer, using the [[https:// | ||
- Follow instructions in VE Power Setup. | - Follow instructions in VE Power Setup. | ||
Line 44: | Line 48: | ||
Check the information behind the '' | Check the information behind the '' | ||
- | ===== 3. Remote VE.Can firmware update ===== | + | ===== 3. Remote VE.Can firmware update |
- | ==== 3.1 Remote VE.Can update: | + | Note that this feature is deprecated; and only works for GX devices running old firmware. Instead of following the remote firmware procedure as documented on this page, we recommend to update the GX Device to the latest available firmware version, and then use the procedures documented [[vrm_portal: |
+ | ==== 3.1 Instructions ==== | ||
- Obtain the necessary firmware file on [[https:// | - Obtain the necessary firmware file on [[https:// | ||
Line 55: | Line 61: | ||
- After selecting the site, VE Power Setup will establish communication to the selected site. | - After selecting the site, VE Power Setup will establish communication to the selected site. | ||
- Once established, | - Once established, | ||
- | ==== 3.2 Remote VE.Can update: | + | ==== 3.2 Troubleshooting ==== |
- Check the [[ccgx: | - Check the [[ccgx: | ||
- | ===== 4. Remote VEConfigure ===== | + | ===== 4. Remote VEConfigure |
- | ==== 4.1 Remote VEConfigure: | + | Note that this feature is deprecated; and only works for GX devices running v2.16 or earlier. To remotely configure inverter/ |
+ | ==== 4.1 Requirements ==== | ||
* Remote VEConfigure works for both single unit systems as parallel and three phase systems. | * Remote VEConfigure works for both single unit systems as parallel and three phase systems. | ||
Line 71: | Line 79: | ||
If the VE.Bus device is connected to the CCGX via a VE.Bus to VE.Can interface, as was often the case in a Hub-1 system, this interface cable needs to run firmware version v2.05 or higher. Note that it is possible to first update the firmware in the interface cable, and then remotely configure the VE.Bus system. | If the VE.Bus device is connected to the CCGX via a VE.Bus to VE.Can interface, as was often the case in a Hub-1 system, this interface cable needs to run firmware version v2.05 or higher. Note that it is possible to first update the firmware in the interface cable, and then remotely configure the VE.Bus system. | ||
- | ==== 4.2 Remote VEConfigure: | + | ==== 4.2 Instructions ==== |
Line 90: | Line 98: | ||
- Select the modified setting file and wait until done. | - Select the modified setting file and wait until done. | ||
- | ==== 4.2 Inverter restart - short loss of AC power ==== | + | ==== 4.3 Inverter restart - short loss of AC power ==== |
Changing certain settings, such as Assistants, will cause the inverter/ | Changing certain settings, such as Assistants, will cause the inverter/ | ||
Line 101: | Line 109: | ||
And it is important that the CCGX (or Venus GX) is powered from DC: it should not lose power during this process. | And it is important that the CCGX (or Venus GX) is powered from DC: it should not lose power during this process. | ||
- | ==== 4.2 Remote VEConfigure: | + | ==== 4.4 Troubleshooting ==== |
- | === Problem in the communication link between your computer and the Remote | + | === Problem in the communication link between your computer and the Remote |
Check the [[ccgx: | Check the [[ccgx: | ||
=== Error, remote Color Control gave VEConfig error code 30: MK2 communication error === | === Error, remote Color Control gave VEConfig error code 30: MK2 communication error === | ||
- | Verify that both the firmware of the VE.Bus system and the Venus Device | + | Verify that both the firmware of the VE.Bus system and the [[venus-os: |
- | ===== 5. Two-way communication ===== | + | ===== 5. Two-way communication |
+ | The information in this chapter describes deprecated functionality. For both remote firmware updates and Remote VEConfigure, | ||
+ | * [[vrm_portal: | ||
+ | (old text continues) | ||
+ | Two-way communication is the name of the technology used for the communication link between your computer and the [[venus-os: | ||
- | Two-way communication is the name of the technology used for the communication link between your computer and the Venus Device during Remote Firmware updates and Remote VEConfigure. | ||
==== 5.1 Configuration ==== | ==== 5.1 Configuration ==== | ||
- Use the latest version of the [[https:// | - Use the latest version of the [[https:// | ||
- Use the latest version of [[https:// | - Use the latest version of [[https:// | ||
- | - Check that the Venus device runs the latest available firmware. | + | - Check that the [[venus-os: |
- | - Enable Two-way communication on the Venus device. | + | - Enable Two-way communication on the [[venus-os: |
- Make sure to have Full Control access on the installation: | - Make sure to have Full Control access on the installation: | ||
- CCGX must be connected to internet, and Two-way communication must show as up in the Device list on the VRM Portal. | - CCGX must be connected to internet, and Two-way communication must show as up in the Device list on the VRM Portal. | ||
- | This screenshot shows the Device list on the VRM Portal. See Venus device firmware version, as well as Two-way communication status encircled in red: | + | This screenshot shows the Device list on the VRM Portal. See [[venus-os: |
==== 5.2 Two way communication: | ==== 5.2 Two way communication: | ||
- | As a first stap, carefully go through above steps of configuring Two-way communication. | + | As a first step, carefully go through above steps of configuring Two-way communication. |
=== Error "VRM API not responding" | === Error "VRM API not responding" | ||
Line 154: | Line 170: | ||
* If you get a crash right at start up, you need to install the [[http:// | * If you get a crash right at start up, you need to install the [[http:// | ||
ccgx/ccgx_ve_power_setup.txt · Last modified: 2023-05-07 09:53 by mvader
