ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-06-27 15:35] – iburger | ccgx:ccgx_fronius [2019-09-18 07:52] – [2.2 Adding Fronius to the CCGX] mvader | ||
Line 80: | Line 80: | ||
4. Configure the // | 4. Configure the // | ||
* Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | ||
- | * Phase: = the phase on which the PV Inverter installed. | + | * Phase: = the phase on which the PV Inverter installed. |
* Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | ||
