ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:ccgx_fronius [2019-06-27 15:35] – iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 108: | Line 108: | ||
+ | ^ State ^ Meaning ^ | ||
===== 4. Monitoring on the VRM Portal ===== | ===== 4. Monitoring on the VRM Portal ===== |
