ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-01-21 11:05] – guy_stewart | ccgx:ccgx_fronius [2019-12-03 15:30] – [2.2 Adding Fronius to the CCGX] iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 28: | Line 28: | ||
==== 2.1 Setup Local Area Network (LAN) Configuration==== | ==== 2.1 Setup Local Area Network (LAN) Configuration==== | ||
- | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius, using one of the following methods: | + | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius, using one of the following methods. If you are in doubt, which method is the best for your network, please ask your system administrator or IT support. |
=== 2.1.1 DHCP addressing method === | === 2.1.1 DHCP addressing method === | ||
Line 45: | Line 45: | ||
=== 2.1.3 manual addressing method === | === 2.1.3 manual addressing method === | ||
- | === Markus === | ||
- | 1. You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. The IP configuration can be reviewed in Settings --> Ethernet. IP address and Subnet Mask, are the settings of importance. If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. Configuring the Fronius to the same subnet means setting a manual IP address to: 192.168.10.2 and the same Subnet Mask of 255.255.255.0 on the Fronius. It is important to say, that every device on your LAN has to have a unique (different) address and so the last segment (.1/.2) in this example has to differ on every device on the same LAN. The highest value, that can be set for this segment is 254. The subnet is described by the first 3 segments in this case and so they have to be the same. Configuring multiple devices with exactly the same IP addresses (same last segment) will lead to network errors and should be avoided at all events. Use different IP subnets for the WiFi and wired LAN interface. The IP address ranges used on each interface should differ in the third segment. | ||
- | As an example: 192.168.10.1-254 for LAN IP's and 192.168.11.1-254 for WiFi IP's. | ||
- | 2. Configure the Fronius Datamanager, | ||
- | === GUY === | ||
You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. | You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. | ||
Line 70: | Line 57: | ||
Every device on your LAN has to have a unique (different) IP address and so the last segment (.1/.2) in this example has to differ on every device on the same LAN. The highest value, that can be set for this segment is 254. | Every device on your LAN has to have a unique (different) IP address and so the last segment (.1/.2) in this example has to differ on every device on the same LAN. The highest value, that can be set for this segment is 254. | ||
- | The subnet is described by the first 3 segments in this case and so they have to be the same. Configuring multiple devices with exactly the same IP addresses | + | The subnet is described by the first 3 segments in this case and so they have to be the same. Configuring multiple devices with exactly the same IP addresses will lead to network errors. Use different IP subnets for the WiFi and wired LAN interface. The IP address ranges used on each interface should differ in the third segment. |
As an example: 192.168.10.1-254 for LAN IP's and 192.168.11.1-254 for WiFi IP's. | As an example: 192.168.10.1-254 for LAN IP's and 192.168.11.1-254 for WiFi IP's. | ||
Line 85: | Line 72: | ||
==== 2.2 Adding Fronius to the CCGX ==== | ==== 2.2 Adding Fronius to the CCGX ==== | ||
- | 1. In the CCGX, navigate to // | + | 1. In the CCGX, navigate to // |
2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
- | 3. Once located, you will see the Inverters listed in the menu. The name used will be the serial number | + | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address |
- | 4. Configure | + | * We recommend that automatic scanning is enabled (the default) in residential |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | * In larger installations, |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | * Note that if DHCP is used to allocate dynamic addresses in your computer network, |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | 5. Done! | + | 4. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: |
+ | 5. Configure the // | ||
+ | 7. Done! | ||
==== 2.3 Device scan details ==== | ==== 2.3 Device scan details ==== | ||
As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
Line 104: | Line 101: | ||
All data cards found will be entered in the ' | All data cards found will be entered in the ' | ||
- | If you changed | + | If you don't want an automatic scan to be performed, disable the //Automatic scanning// setting on the PV-inverters menu. |
===== 3. Monitoring CCGX ===== | ===== 3. Monitoring CCGX ===== | ||
Line 121: | Line 118: | ||
+ | ^ State ^ Meaning ^ | ||
===== 4. Monitoring on the VRM Portal ===== | ===== 4. Monitoring on the VRM Portal ===== | ||
Line 127: | Line 134: | ||
+ | ~~DISQUS~~ | ||
