ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-01-21 00:44] – [2.1 Setup Local Area Network (LAN) Configuration] markus_pauritsch | ccgx:ccgx_fronius [2019-09-18 10:16] – [2.2 Adding Fronius to the CCGX] iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 28: | Line 28: | ||
==== 2.1 Setup Local Area Network (LAN) Configuration==== | ==== 2.1 Setup Local Area Network (LAN) Configuration==== | ||
- | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius | + | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius, using one of the following methods. If you are in doubt, which method is the best for your network, please ask your system administrator or IT support. |
=== 2.1.1 DHCP addressing method === | === 2.1.1 DHCP addressing method === | ||
- | If you have a DHCP server running on the LAN the Fronius and CCGX is connected to, you don't need to manually configure your LAN IP addresses as the DHCP server does this for you. Make sure, that the "IP Switch" | + | If you have a DHCP server running on the LAN the Fronius and CCGX are connected to, you don't need to manually configure your LAN IP addresses as the DHCP server does this for you. Make sure, that the "IP Switch" |
=== 2.1.2 Link-local addressing method | === 2.1.2 Link-local addressing method | ||
When no DHCP server is present on the LAN and you only have one Fronius unit to connect, Link-local addressing can be used to establish data communication between the CCGX and the Fronius. | When no DHCP server is present on the LAN and you only have one Fronius unit to connect, Link-local addressing can be used to establish data communication between the CCGX and the Fronius. | ||
This could be the case, if you use a WiFi Network for the CCGX to gain access to the Internet and have a Fronius connected to the wired LAN Interface of that CCGX. | This could be the case, if you use a WiFi Network for the CCGX to gain access to the Internet and have a Fronius connected to the wired LAN Interface of that CCGX. | ||
Note, that no direct access to the internet will be possible for the Fronius in that configuration and therefore only communication to the CCGX is possible. | Note, that no direct access to the internet will be possible for the Fronius in that configuration and therefore only communication to the CCGX is possible. | ||
This method can only be used to configure a single Fronius unit within a LAN. Multiple Fronius devices in the same LAN must be configured with DHCP, or manual addressing method. | This method can only be used to configure a single Fronius unit within a LAN. Multiple Fronius devices in the same LAN must be configured with DHCP, or manual addressing method. | ||
- Make sure the "IP Switch" | - Make sure the "IP Switch" | ||
Line 43: | Line 45: | ||
=== 2.1.3 manual addressing method === | === 2.1.3 manual addressing method === | ||
- | 1. You will have to configure the IP address of the Fronius to be in the same subnet as the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. The IP configuration can be reviewed in Settings --> Ethernet. IP address and Subnet Mask, the CCGX is actually using, are the settings of importance. If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. Configuring the Fronius to the same Subnet | + | You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. |
+ | The IP configuration can be reviewed in Settings --> Ethernet. | ||
+ | If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. | ||
+ | As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. | ||
+ | Configuring the Fronius to the same subnet | ||
+ | Every device on your LAN has to have a unique (different) | ||
+ | The subnet | ||
+ | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the CCGX. | ||
- | 2. Configure the Fronius Datamanager, | ||
==== 2.2 Adding Fronius to the CCGX ==== | ==== 2.2 Adding Fronius to the CCGX ==== | ||
- | 1. In the CCGX, navigate to // | + | 1. In the CCGX, navigate to // |
2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
- | 3. Once located, you will see the Inverters listed in the menu. The name used will be the serial number | + | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address |
- | 4. Configure | + | 4. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | 5. Done! | + | 5. Configure the // |
+ | 7. Done! | ||
==== 2.3 Device scan details ==== | ==== 2.3 Device scan details ==== | ||
As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
Line 68: | Line 97: | ||
All data cards found will be entered in the ' | All data cards found will be entered in the ' | ||
- | If you changed | + | If you don't want an automatic scan to be performed, disable the //Automatic scanning// setting on the PV-inverters menu. |
===== 3. Monitoring CCGX ===== | ===== 3. Monitoring CCGX ===== | ||
Line 85: | Line 114: | ||
+ | ^ State ^ Meaning ^ | ||
===== 4. Monitoring on the VRM Portal ===== | ===== 4. Monitoring on the VRM Portal ===== | ||
Line 91: | Line 130: | ||
