ccgx:ccgx_fronius
ccgx:ccgx_fronius [2019-01-20 19:49] – [2.1 Setup Local Area Network (LAN) Configuration] markus_pauritsch | ccgx:ccgx_fronius [2020-03-19 15:30] (current) – guy_stewart | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | This manual |
- | - See Fronius information on the CCGX. | + | |
- | - Monitor the Fronius on the VRM Portal. | + | |
- | - Allow the Victron system to control the Fronius output power, Zero feed-in. See the [[ess: | + | |
- | This document describes how to setup the monitoring functions. For more information on using Fronius PV Inverters in a Victron system, see: [[ac_coupling: | + | |
- | ===== 1. Requirements ===== | + | |
- | ^ Model ^ Required accessory ^ | + | |
- | | Fronius Symo Light | Purchase and install the [[http:// | + | |
- | | Fronius Symo | No accessory needed, datamanager card installed from factory | | + | |
- | | Fronius Galvo | No accessory needed, datamanager card installed from factory | | + | |
- | | Fronius Primo | No accessory needed, datamanager card installed from factory | | + | |
- | | Fronius IG Plus (*) | Purchase and install the [[http:// | + | |
- | | Fronius Agilo | Purchase and install the [[http:// | + | |
- | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | + | |
- | All recent Fronius inverters - for example the Fronius Primo - will arrive fitted with a // | + | |
- | Both the Fronius and the CCGX need to be connected on the same LAN - either via Wi-Fi or Ethernet. | + | |
- | Note that the [[http:// | + | |
- | ===== 2. Configuring ===== | + | |
- | ==== 2.1 Setup Local Area Network (LAN) Configuration==== | + | |
- | === 2.1.1 Setup using Manual Addressing or DHCP === | + | |
- | - Connect both, the Fronius and the CCGX, on the same LAN network and configure the IP address of the Fronius to be in the same subnet as the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that LAN network. The IP configuration can be reviewed in Settings --> Ethernet. IP address and Subnet Mask, the CCGX is actually using, are the settings we need to know. As an example, the IP address on the CCGX could look like: 192.168.1.1 and the Subnet Mask: 255.255.255.0. Configuring the Fronius to the same Subnet means setting a manual IP address to: 192.168.1.2 and the same Subnet Mask of 255.255.255.0 on the Fronius. It is important to say that every device on your LAN has to have a unique (different) address and so the last segment (.1/.2) in this example has to differ on every device on the same LAN. The Subnet is described by the first 3 segments in this case and so they have to be the same. Configuring devices with exactly the same IP addresses (same last segment) will lead to network errors and should be avoided at all events. | + | |
- | - Configure the Fronius Datamanager, | + | |
- | - In the CCGX, navigate to // | + | |
- | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | + | |
- | - Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: | + | |
- | - Configure the // | + | |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | - Done! | + | |
- | === 2.1.2 Setup using Link-local addressing === | + | |
- | If you don't use a router or have some other DHCP Server service available on your LAN to configure your IP addresses and don't want or have the possibility to manually configure IP addresses, Link-local addressing can be used to establish data communication between the CCGX and the Fronius. | + | |
- | This could be the case when you use a WiFi Network for the CCGX to access the Internet and have a Fronius connected directly to the wired LAN Interface of that CCGX. | + | |
- | Note, that no access to the internet will be possible for the Fronius in that configuration and therefore only communication to the CCGX is possible. | + | |
- | This method can only be used to configure one single Fronius unit in a LAN. Multiple Fronius devices in the same LAN must be configured using manual or DHCP addressing method. | + | |
- | - Make sure the "IP Switch" | + | |
- | - Connect both, the Fronius and the CCGX, on the same LAN network | + | |
- | - The Fronius is now accessible and having a " | + | |
- | ==== 2.1 Device scan details ==== | + | |
- | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | + | |
- | Usually a scan is completed within a minute - though if you have a large subnet it may take much more time. If you don't want to wait for completion, enter an IP-address manually. | + | |
- | All data cards found will be entered in the ' | + | |
- | If you changed to //TCP// port number on the data manager, you should change this setting on the CCGX, too (TCP port) - otherwise leave the setting at its default (80). | + | |
- | ==== 3. Monitoring CCGX ==== | + | |
- | When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | + | |
- | To see the device details, navigate to the menu. | + | |
- | Here you can see the current state, current power generated, total power generated. | + | |
- | For more details on each device navigate to the Device menu. Here you will find: IP address, Product name, product ID, and Serial number, etc. | + | |
- | ==== 4. Monitoring on the VRM Portal ==== | + | |
- | To see the yield on the VRM site (in the // | + | |
