ccgx:ccgx_fronius
ccgx:ccgx_fronius [2018-03-21 11:54] – mvader | ccgx:ccgx_fronius [2019-09-18 10:16] – [2.2 Adding Fronius to the CCGX] iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 13: | Line 13: | ||
| Fronius Symo | No accessory needed, datamanager card installed from factory | | | Fronius Symo | No accessory needed, datamanager card installed from factory | | ||
| Fronius Galvo | No accessory needed, datamanager card installed from factory | | | Fronius Galvo | No accessory needed, datamanager card installed from factory | | ||
| Fronius IG Plus (*) | Purchase and install the [[http:// | | Fronius IG Plus (*) | Purchase and install the [[http:// | ||
| Fronius Agilo | Purchase and install the [[http:// | | Fronius Agilo | Purchase and install the [[http:// | ||
Line 26: | Line 27: | ||
===== 2. Configuring ===== | ===== 2. Configuring ===== | ||
- | ==== 2.1 Setup ==== | + | ==== 2.1 Setup Local Area Network (LAN) Configuration==== |
+ | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius, using one of the following methods. If you are in doubt, which method is the best for your network, please ask your system administrator or IT support. | ||
- | - Connect both the Fronius and the CCGX on the same LAN network, in the same subnet. (If you don' | + | === 2.1.1 DHCP addressing method === |
- | - Configure the Fronius datamanager using its manual. (On DHCP networks, no configuration of the datamanager | + | If you have a DHCP server running on the LAN the Fronius and CCGX are connected to, you don' |
- | - In the CCGX, navigate | + | |
- | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu | + | |
- | - Once located, you will see the Inverters listed | + | |
- | - Configure the // | + | |
- | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | |
- | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | - Done! | + | |
- | ==== 2.1 Device scan details ==== | + | === 2.1.2 Link-local addressing method |
+ | When no DHCP server is present on the LAN and you only have one Fronius unit to connect, Link-local addressing can be used to establish data communication between the CCGX and the Fronius. | ||
+ | This could be the case, if you use a WiFi Network for the CCGX to gain access to the Internet and have a Fronius connected to the wired LAN Interface of that CCGX. | ||
+ | Note, that no direct access to the internet will be possible for the Fronius in that configuration and therefore only communication to the CCGX is possible. | ||
+ | - Connect both, the Fronius and the CCGX, on the same LAN network, either directly with a LAN cable or using a network switch. | ||
+ | === 2.1.3 manual addressing method === | ||
+ | You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. | ||
+ | If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. | ||
+ | As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. | ||
+ | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the CCGX. | ||
+ | ==== 2.2 Adding Fronius to the CCGX ==== | ||
+ | 1. In the CCGX, navigate to // | ||
+ | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
+ | 3. The CCGX will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address of the PV-inverter changes. To prevent automatic scanning, disable //Automatic scanning// | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ==== 2.3 Device scan details ==== | ||
As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
Line 46: | Line 97: | ||
All data cards found will be entered in the ' | All data cards found will be entered in the ' | ||
- | If you changed | + | If you don't want an automatic scan to be performed, disable the //Automatic scanning// setting on the PV-inverters menu. |
+ | ===== 3. Monitoring CCGX ===== | ||
- | ==== 3. Monitoring CCGX ==== | ||
When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | ||
Line 63: | Line 115: | ||
+ | ^ State ^ Meaning ^ | ||
+ | ===== 4. Monitoring on the VRM Portal ===== | ||
- | ==== 4. Monitoring on the VRM Portal ==== | ||
To see the yield on the VRM site (in the // | To see the yield on the VRM site (in the // | ||
Line 71: | Line 133: | ||
