ccgx:ccgx_fronius
ccgx:ccgx_fronius [2017-09-01 11:55] – [CCGX & Fronius PV Inverters] mvader | ccgx:ccgx_fronius [2019-06-27 15:35] – iburger | ||
====== CCGX & Fronius PV Inverters ====== | ====== CCGX & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and [[https:// | + | By connecting a Fronius PV Inverter and [[https:// |
- See Fronius information on the CCGX. | - See Fronius information on the CCGX. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
- | - Fronius kWh reading will be used for the solar yield and also the consumption tab on VRM. | + | - Allow the Victron system |
- | - Have the Victron system control the Fronius output power, Zero feed-in. See the [[ess: | + | |
- | This document describes how to setup the monitoring functions. | + | This document describes how to setup the monitoring functions. |
===== 1. Requirements ===== | ===== 1. Requirements ===== | ||
Line 14: | Line 13: | ||
| Fronius Symo | No accessory needed, datamanager card installed from factory | | | Fronius Symo | No accessory needed, datamanager card installed from factory | | ||
| Fronius Galvo | No accessory needed, datamanager card installed from factory | | | Fronius Galvo | No accessory needed, datamanager card installed from factory | | ||
- | | Fronius IG Plus | Purchase and install the [[http:// | + | | Fronius Primo | No accessory needed, datamanager card installed from factory | |
| Fronius Agilo | Purchase and install the [[http:// | | Fronius Agilo | Purchase and install the [[http:// | ||
- | All the new inverters, for example the upcoming Fronius Primo are fitted by default with the datamanager 2.0. | + | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: |
- | Both the Fronius and the CCGX need to be connected on the same LAN, either via Wi-Fi or Ethernet. | + | All recent Fronius inverters - for example the Fronius Primo - will arrive fitted with a // |
+ | Both the Fronius and the CCGX need to be connected on the same LAN - either via Wi-Fi or Ethernet. | ||
Note that the [[http:// | Note that the [[http:// | ||
Line 25: | Line 27: | ||
===== 2. Configuring ===== | ===== 2. Configuring ===== | ||
- | ==== 2.1 Setup ==== | + | ==== 2.1 Setup Local Area Network (LAN) Configuration==== |
+ | In order to establish a data communication between the Fronius and the CCGX, you will have to setup a valid LAN IP address on the Fronius, using one of the following methods. If you are in doubt, which method is the best for your network, please ask your system administrator or IT support. | ||
- | - Connect both the Fronius and the CCGX on the same LAN network, in the same subnet. If you don' | + | === 2.1.1 DHCP addressing method === |
- | - Configure the Fronius datamanager according to its manual. (On DHCP networks, no configuration of the datamanager | + | If you have a DHCP server running on the LAN the Fronius and CCGX are connected to, you don' |
- | - In the CCGX, navigate | + | |
- | - Press scan in the CCGX menu, and after completion go into the Inverters submenu | + | |
- | - After it has found inverters, you can see them in the Inverters menu. The name used in the menu is the serial number | + | |
- | - Configure the position relative to the Multi or Quattro (AC Input / AC Output). and phase for each inverter in the list: \\ {{: | + | |
- | * Position: the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | + | |
- | * Phase: the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | + | |
- | * Show: show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | + | |
- | - Done! | + | |
- | ==== 2.1 Device scan details ==== | + | === 2.1.2 Link-local addressing method |
- | As mentioned above the CCGX should find all Fronius | + | When no DHCP server is present on the LAN and you only have one Fronius |
+ | This could be the case, if you use a WiFi Network for the CCGX to gain access to the Internet and have a Fronius connected | ||
- | Usually a device scan is completed within a minute. If you have a large subnet, the scan may need much more time. If you don't want to wait for completion, you can enter an IP-address manually. | + | Note, that no direct access |
- | All data cards found will be inserted into the ' | + | This method can only be used to configure a single Fronius unit within a LAN. Multiple Fronius devices in the same LAN must be configured with DHCP, or manual addressing method. |
- | If you changed to TCP port number on the data manager, you can change this as well on the CCGX (TCP port). Otherwise, | + | === 2.1.3 manual addressing method === |
+ | You will have to configure the IP address of the Fronius to be in the same subnet as the IP address of the CCGX. To do this, first have a look at the IP configuration your CCGX is using on that network. | ||
+ | If the LAN IP address and Subnet Mask of the CCGX is not configured yet, you will have to set it first. | ||
+ | As an example, the IP address on the CCGX could be: 192.168.10.1 and the Subnet Mask: 255.255.255.0. | ||
+ | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the CCGX. | ||
+ | ==== 2.2 Adding Fronius to the CCGX ==== | ||
+ | 1. In the CCGX, navigate to // | ||
+ | 2. Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the Fronius Datamanager < | ||
+ | 3. Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter - which you will also find on the inverter itself: \\ {{: | ||
+ | 4. Configure the // | ||
+ | * Position: = the position relative to the Multi or Quattro [AC Input 1 / AC Input 2 / AC Output] | ||
+ | * Phase: = the phase on which the PV Inverter installed. Disabled and set to Multi-phase for split- and three-phase PV Inverters | ||
+ | * Show: = show this device in the system or not. Use this feature when there are multiple, separate, energy systems on the same LAN. | ||
+ | 5. Done! | ||
+ | ==== 2.3 Device scan details ==== | ||
+ | As mentioned above the CCGX should find all Fronius inverters automatically. It will scan all IP-addresses in the local network (that is, all IP-addresses within the netmask assigned to the CCGX) to check whether or not they are //Fronius datamanager// | ||
+ | If you changed to //TCP// port number on the data manager, you should | ||
+ | ===== 3. Monitoring CCGX ===== | ||
+ | When the Fronius is detected and configured on the CCGX all PV inverters will be visible in the devicelist. | ||
- | ==== 3. Monitoring CCGX ==== | ||
- | When the Fronius is detected and configured on the CCGX every PV inverter will be visible in the devicelist. | ||
- | To see the device details navigate | + | To see the device details, navigate |
- | Here you can see the current state, current power generated, total power generated | + | Here you can see the current state, current power generated, total power generated. |
- | For more details on the device navigate | + | For more details on each device navigate |
- | ==== 4. Monitoring on the VRM Portal ==== | + | The following status values are supported: |
- | To see the yield on the VRM site in the Advanced tab, do not forget to enable the PV Inverter yield widget(s) in Settings -> Advanced tab setup. | + | ^ State ^ Meaning ^ |
+ | ===== 4. Monitoring on the VRM Portal ===== | ||
+ | To see the yield on the VRM site (in the //Advanced// tab), don' | ||
Line 67: | Line 127: | ||
