ccgx:beta-testing
ccgx:beta-testing [2019-08-25 07:13] – [How do I know if the firmware I am running is a beta version?] mvader | ccgx:beta-testing [2023-06-03 22:44] – [Venus OS - Beta testing] mvader | ||
Would you like to become a Beta tester? | Would you like to become a Beta tester? | ||
- | Venus OS - or //Venus// for short - is the operating software for our //Color Control | + | Venus OS - or //Venus// for short - is the operating software for our range of GX monitoring products, such as the Cerbo GX. Extensive field testing over a wide variety of installation-types and user-cases is very valuable to us ...and we're very grateful to you for your interest in joining this program, and for your help. |
==== What happens when I join the program? ==== | ==== What happens when I join the program? ==== | ||
Line 15: | Line 15: | ||
This is a note to dealers & installers: **Do not install test versions on a customer' | This is a note to dealers & installers: **Do not install test versions on a customer' | ||
- | These versions are called //test versions//, or // | + | These versions are called |
- | ==== Where should I post possible | + | Also, don't contact Victron dealers, installers, support, or sales managers or anyone else in case you see problems while running a beta version. The only channel for issues in such case is the relevant open Venus OS post on the Modifications section on Community. |
+ | ==== Where should I post possible | ||
If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | ||
If the problem also exists with the official release; then contact normal support. | If the problem also exists with the official release; then contact normal support. | ||
- | If the problem only exists in the beta version, then please | + | If the problem only exists in the beta version, then please |
And don't forget to mention which test version you are using. | And don't forget to mention which test version you are using. | ||
Line 39: | Line 40: | ||
http:// | http:// | ||
- | You will find the Venus GX images in the directory titled: //beaglebone///. | + | Which directory to use depends on the GX Device you have: |
+ | * Venus GX: beaglebone | ||
+ | * Cerbo GX: einstein | ||
+ | * MultiPlus-II GX, or EasySolar-II GX: nanopi | ||
Line 51: | Line 56: | ||
==== Where can I find the change logs? ==== | ==== Where can I find the change logs? ==== | ||
- | Change logs for beta versions are on the [[https:// | + | Change logs for beta versions are on the [[https:// |
Change logs of the official releases are on [[https:// | Change logs of the official releases are on [[https:// | ||
Line 63: | Line 68: | ||
==== How can I unsubscribe to the emails? ==== | ==== How can I unsubscribe to the emails? ==== | ||
- | By un-joining | + | |
+ | Only be changing | ||
+ | ==== How can I leave the beta testing | ||
+ | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
+ | There, select //Latest release//. | ||
+ | The other option, | ||
ccgx/beta-testing.txt · Last modified: 2023-07-05 07:30 by mvader
