ccgx:beta-testing
ccgx:beta-testing [2019-08-25 07:13] – [How do I know if the firmware I am running is a beta version?] mvader | ccgx:beta-testing [2020-07-30 09:25] – [Where can I find the change logs?] mvader | ||
Line 17: | Line 17: | ||
These versions are called //test versions//, or // | These versions are called //test versions//, or // | ||
- | ==== Where should I post possible | + | ==== Where should I post possible |
If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | If you think you have found a bug, first of all install the latest official release again (a version without the ~ notation) to check that if that solves it. Sometimes you can go back by using the Backup firmware option. If that also contains a beta version, then you’ll need to install the official version by hand. Download the .swu file from https:// | ||
If the problem also exists with the official release; then contact normal support. | If the problem also exists with the official release; then contact normal support. | ||
- | If the problem only exists in the beta version, then please | + | If the problem only exists in the beta version, then please |
And don't forget to mention which test version you are using. | And don't forget to mention which test version you are using. | ||
Line 51: | Line 51: | ||
==== Where can I find the change logs? ==== | ==== Where can I find the change logs? ==== | ||
- | Change logs for beta versions are on the [[https:// | + | Change logs for beta versions are on the [[https:// |
Change logs of the official releases are on [[https:// | Change logs of the official releases are on [[https:// | ||
Line 63: | Line 63: | ||
==== How can I unsubscribe to the emails? ==== | ==== How can I unsubscribe to the emails? ==== | ||
- | By un-joining | + | |
+ | Only be changing | ||
+ | ==== How can I leave the beta testing | ||
+ | On your GX Device, go to Settings -> Firmware -> Online updates -> Update to. | ||
+ | There, select //Latest release//. | ||
+ | The other option, | ||
ccgx/beta-testing.txt · Last modified: 2023-07-05 07:30 by mvader
