ccgx:abb_fimer
ccgx:abb [2019-07-15 18:51] – [2. Supported models] rgerber | ccgx:abb_fimer [2021-02-27 17:29] – [3. Configuration] rgerber | ||
- | ====== CCGX & ABB PV Inverters ====== | + | ====== CCGX & ABB/ |
- | By connecting an ABB PV Inverter and [[https:// | + | By connecting an ABB/ |
- | - See ABB information on the CCGX. | + | - See ABB/ |
- | - Monitor the ABB inverter on the VRM Portal. | + | - Monitor the ABB/ |
- Allow the Victron system to control the output power, Zero feed-in. This uses the same mechanism used for Fronius PV inverters. See the [[ess: | - Allow the Victron system to control the output power, Zero feed-in. This uses the same mechanism used for Fronius PV inverters. See the [[ess: | ||
- Frequency shift power control, as explained in [[ac_coupling: | - Frequency shift power control, as explained in [[ac_coupling: | ||
Line 13: | Line 13: | ||
Models that are known to work are: | Models that are known to work are: | ||
- | ^ Model | + | ^ Model |
- | | UNO-DM-PLUS | + | | UNO-DM-PLUS/ |
- | | TRIO-TM-50/ | + | | TRIO-TM-50/ |
- | | PVS-100/ | + | | PVS-100/ |
- | | PVS-50/ | + | | PVS-10/ |
- | Please consult the manual that came with your ABB PV inverter. This explains how to connect your ABB inverter to the network using either an Ethernet or a WiFi connection. Commissioning the inverter | + | Please consult the manual that came with your ABB/ |
+ | You can also use the " | ||
+ | Commissioning the inverter | ||
+ | When using the app, simply scan the QR code for the WiFi access and follow instructions on the app. This can be used to program multiple inverters simultaneously. | ||
+ | When using the webserver, follow instructions below: | ||
- Switch on DC power to inverter (leave AC off). | - Switch on DC power to inverter (leave AC off). | ||
Line 33: | Line 40: | ||
===== 4. Adding the ABB inverter to the CCGX ===== | ===== 4. Adding the ABB inverter to the CCGX ===== | ||
- In the CCGX, navigate to // | - In the CCGX, navigate to // | ||
- | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the ABB inverter. | + | - Select //Scan// in the CCGX menu, and after completion go into the Inverters submenu to see the results. If scanning does not find the inverter, manually add the IP address of the ABB/ |
- Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter. | - Once located, you will see the Inverters listed in the menu. The name used will be the serial number of the inverter. | ||
- Configure the // | - Configure the // |
ccgx/abb_fimer.txt · Last modified: 2021-06-16 15:30 by rgerber
