battery_compatibility:zyc_energy
| battery_compatibility:zyc_energy [2025-03-05 01:47] – guy_stewart | battery_compatibility:zyc_energy [2026-06-11 13:14] (current) – guy_stewart | ||
| Line 13: | Line 13: | ||
| === 1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible === | === 1.2 All 48V Multis, MultiPlus, Quattros and RS models are compatible === | ||
| - | The minimum supported firmware version for VE.Bus models is 469. Minimum supported firmware for RS models is 1.16. Updating | + | The minimum supported firmware version for VE.Bus models is 469. These inverter/ |
| - | These inverter/ | + | Minimum supported firmware for Inverter RS and Multi RS models is 1.16, and these must be connected via the VE.Can port, on a seperate VE.Can (250kbps) interface. |
| + | Updating to the latest firmware is recommended for new installations, | ||
| In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | ||
| Line 68: | Line 70: | ||
| ===== 3. Further system integration documentation | ===== 3. Further system integration documentation | ||
| - | A [[https:// | + | Please note that these may not be the latest revisions, always check with your battery supplier first for the most up-to-date information. |
| - | [[https:// | + | A QuickStart guide with further |
| - | ===== 3. Installation Video ===== | + | {{ : |
| + | Their product manual contains further information here. | ||
| + | ===== 3.1 Installation Video ===== | ||
| {{youtube> | {{youtube> | ||
| Line 95: | Line 103: | ||
| Victron does not store ZYC firmware files on VRM, nor does it know what the latest firmware version is, or if there is an update available. | Victron does not store ZYC firmware files on VRM, nor does it know what the latest firmware version is, or if there is an update available. | ||
| Line 107: | Line 112: | ||
| **Perform the Update** | **Perform the Update** | ||
| + | ZYC has prepared a step by step guide here - {{ : | ||
| + | There is a screen recording of the process here - {{ : | ||
| Open the device list for the site, click the Firmware update button. If there is no firmware update button; [[https:// | Open the device list for the site, click the Firmware update button. If there is no firmware update button; [[https:// | ||
| Line 118: | Line 128: | ||
| After completion, check the battery’s firmware version in VRM and monitor for any system issues. The VRM firmware update is applied to the Master battery, for large systems it can take some time for the ZYC BMS to then automatically update the firmware of the other connected batteries. | After completion, check the battery’s firmware version in VRM and monitor for any system issues. The VRM firmware update is applied to the Master battery, for large systems it can take some time for the ZYC BMS to then automatically update the firmware of the other connected batteries. | ||
| - | ZYC has prepared a step by step guide here - {{ : | ||
| - | There is a screen recording of the process here - {{ : | ||
| ===== 5. Support | ===== 5. Support | ||
| Line 126: | Line 133: | ||
| Support for this battery should first come from your ZYC Energy supplier. | Support for this battery should first come from your ZYC Energy supplier. | ||
| - | Support from Victron is limited to our online [[https:// | ||
battery_compatibility/zyc_energy.1741139228.txt.gz · Last modified: by guy_stewart
