battery_compatibility:solar_md
battery_compatibility:solar_md [2019-08-15 11:46] – replace Venus-device with GX device guy_stewart | battery_compatibility:solar_md [2022-06-18 14:14] (current) – kaloyan | ||
Line 8: | Line 8: | ||
== Supported models == | == Supported models == | ||
- | ^ Model ^ SS4037^ SS4074^ SS202^ | + | ^ Model ^ SS4037^ SS4074^ SS202^ SS4143^ SS3143^ |
- | | Battery | {{ : | + | | Battery | {{ : |
- | |ESS | yes| yes| yes| | + | |ESS | yes| yes| yes| yes| yes| |
- | |Grid Backup | yes| yes| yes| | + | |Grid Backup |
- | |Off-Grid | yes| yes| yes| | + | |Off-Grid |
- | |Module capacity | 3.7kWh| 7, | + | |Module capacity | 3.7kWh| 7, |
- | |Module limit | 256| 256| 256| | + | |Module limit | 256| 256| 256| 256| 256| |
- | |Max capacity | 947 kWh| 1894,4 kWh| 1894,4 kWh| | + | |Max capacity | 947 kWh| 1894,4 kWh| 1894, |
|Logger V2 | yes| yes| yes| | |Logger V2 | yes| yes| yes| | ||
Line 103: | Line 103: | ||
Each battery module is 72Ah (SS4037) or 144Ah (SS4074) at 48V (51.2V nominal). | Each battery module is 72Ah (SS4037) or 144Ah (SS4074) at 48V (51.2V nominal). | ||
- | The following charge rates are managed automatically by the SolarMD LOGGER V2 and [[venus-os: | + | The following charge rates are managed automatically by the SolarMD LOGGER V2 and [[venus-os: |
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the LOGGER V2 triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the LOGGER V2 triggering over-current alarms. | ||
Line 118: | Line 118: | ||
| Multiplus 48/5000/70 | 1| 3| 2| 6| | | Multiplus 48/5000/70 | 1| 3| 2| 6| | ||
- | | Quattro 48/ | + | | Quattro 48/ |
Line 132: | Line 132: | ||
+ | === Battery Modules Required – per 14.3kWh (SS4143)) === | ||
+ | | Phases | Single Phase| Three Phase| Single Phase| Three Phase| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/3000/35 | 1| 1| 1| 2| | ||
+ | | Multiplus 48/5000/70 | 1| 2| 1| 3| | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
===== 3. CAN Bus Wiring ===== | ===== 3. CAN Bus Wiring ===== | ||
Line 233: | Line 245: | ||
- | * On the Solar MD portal ([[http:// | + | * On the Solar MD portal ([[http:// |
Menu path: | Menu path: | ||
- | My Devices → Logger → Interfaces → CANBUS2 . After choosing Victron | + | My Devices → Logger → Interfaces → CANBUS2. After choosing Victron |
Line 277: | Line 290: | ||
+ | ===== 7. NEW Direct communication via BMS EX ===== | ||
+ | ==== 7.1 Communication Cable Connection ==== | ||
+ | It is recommended that CAT5e cable be used. The termination resistor on the last battery should be ON, the rest should be OFF. Please use between all batteries CAN2 and CAN1 straight cable connection. For the last battery to the GX device[[battery_compatibility: | ||
+ | The minimum firmware version of the BMS EX should be v 178 | ||
+ | ==== 7.2 A Battery settings ==== | ||
+ | Refer to the BMS of LoggerV manual to configure the CANBUS 2 interface for a Victron device. Note: After changing CANBUS 2 settings on the battery, the Victron GX device will need to be rebooted. | ||
battery_compatibility/solar_md.txt · Last modified: 2022-06-18 14:14 by kaloyan
