battery_compatibility:solar_md
battery_compatibility:solar_md [2019-07-27 10:19] – created kaloyan | battery_compatibility:solar_md [2019-08-15 11:46] – replace Venus-device with GX device guy_stewart | ||
====== Victron & SOLARMD Battery ====== | ====== Victron & SOLARMD Battery ====== | ||
- | The combination of Victron products with SOLARMD | + | The combination of Victron products with SolarMD |
- | The SOLARMD | + | The SolarMD |
- | ^ Battery ^ SS4037 ^ SS4074 ^ SS202 ^ SS237-25.6V ^ | ||
- | |ESS | yes | yes | yes | yes | | ||
- | Grid Backup | yes | yes | yes | yes | | ||
- | Off-Grid yes yes yes yes | ||
- | Module capacity 3.7 kWh 7.4 kWh 7.4 kWh 3.7kWh | ||
- | Module limit 256 256 256 256 | ||
- | Max capacity 947 kWh 1894,4 kWh 1894,4 kWh 947 kWh | ||
- | 1. Product & System compatibility | ||
- | 1.1 Off grid, Backup and Energy Storage Systems are possible | ||
- | Victron + SOLARMD Battery can be used for the following system types: | ||
- | Energy Storage Systems - Self Consumption (ESS - Start page) | ||
- | Grid Backup | ||
- | Off-grid | ||
- | 1.2 A Venus-device is required, eg Color Control GX (CCGX), Venus GX (VGX), etc | ||
- | It is essential to use the CAN-bus connection of a Venus-device with the SOLARMD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | ||
- | When used with Solar MD batteries, the minimum required firmware version for the Venus-device is v 2.15. Please use the latest firmware version on all connected devices, including CCGX/VGX, Inverter/ | ||
+ | == Supported models == | ||
+ | ^ Model ^ SS4037^ SS4074^ SS202^ | ||
+ | | Battery | {{ : | ||
+ | |ESS | yes| yes| yes| | ||
+ | |Grid Backup | yes| yes| yes| | ||
+ | |Off-Grid | yes| yes| yes| | ||
+ | |Module capacity | 3.7kWh| 7, | ||
+ | |Module limit | 256| 256| 256| | ||
+ | |Max capacity | 947 kWh| 1894,4 kWh| 1894,4 kWh| | ||
+ | |Logger V2 | yes| yes| yes| | ||
+ | For SS237 - 25.6V (24V systems) please contact [[support@solarmd.co.za|Solar MD support team]] for further assistance. | ||
+ | __//== System overview ==//__ | ||
+ | __//== Typical installation with a Single SS4074 and Multiplus II 48/3000 ==//__ | ||
+ | __//== Typical installation with Multiple SS202 modules, 3 Quattros, 3 MPPTs, and Fronius integration ==//__ | ||
+ | ===== 1. Product & System compatibility ===== | ||
+ | ==== 1.1 Off-grid, Backup, and Energy Storage Systems are possible ==== | ||
+ | Victron + SolarMD Battery can be used for the following system types: | ||
+ | * Energy Storage Systems - Self Consumption ([[ess: | ||
+ | * Grid Backup | ||
+ | * Off-grid | ||
+ | ==== 1.2 A GX device is required, eg Color Control GX (CCGX), Venus GX (VGX), etc ==== | ||
+ | It is essential to use the CAN-bus connection of a [[venus-os: | ||
+ | When used with Solar MD batteries, the minimum required firmware version for the [[venus-os: | ||
+ | ==== 1.3 All 48V Multis, MultiPlusses, | ||
- | 1.3 All 48V Multis, MultiPlusses, | ||
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the Venus-device. | + | In grid-connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: |
- | In off-grid systems, the control functions of the SOLARMD Battery Management System (BMS) are built into the latest version of the Venus-device. | + | In off-grid systems, the control functions of the SOLARMD Battery Management System (BMS) are built into the latest version of the [[venus-os: |
- | 1.4 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible | + | |
- | For proper operation, the Battery battery needs to be able to control the charge current of the solar MPPTs. It is recommended to use the MPPTs with VE.Direct port with SOLARMD batteries. | + | ==== 1.4 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible |
+ | For proper operation, the Battery battery needs to be able to control the charge current of the solar MPPTs. It is recommended to use the MPPTs with VE. Direct port with SOLARMD batteries. | ||
MPPTs with a VE.Direct port | MPPTs with a VE.Direct port | ||
- | MPPTs are controlled via the Venus-device. Make sure the Venus-device runs v2.15 or later, and the MPPTs to 1.39 or the latest available version. | + | MPPTs are controlled via the [[venus-os: |
- | The MPPT requires connection to the Venus-device to regulate charge currents as the batteries require (due to temperature, | + | The MPPT requires connection to the [[venus-os: |
MPPTs with a VE.Can port | MPPTs with a VE.Can port | ||
Firmware should be at least version 2.05. | Firmware should be at least version 2.05. | ||
When using VE.Can MPPT' | When using VE.Can MPPT' | ||
- | 1.5 Battery compatibility | + | ==== 1.5 Battery compatibility |
The following batteries are supported for the 48V systems: | The following batteries are supported for the 48V systems: | ||
- | BATTERY LV series type 51.2V | + | ^SolarMD |
- | BATTERY SS4037 | + | |BATTERY SS4037| |
- | BATTERY SS4074 | + | |BATTERY SS4074| |
- | BATTERY SS202 | + | |BATTERY SS202| |
- | SOLARMD | + | |
- | Minimum | + | For SS237 - 25.6V (24V systems) please contact [[support@solarmd.co.za|Solar MD support team]] for further assistance. |
- | This version can be seen on the Solar MD monitoring platform | + | |
+ | Solar MD also releases | ||
+ | Minimum | ||
+ | This version can be seen on the Solar MD monitoring platform. | ||
Batteries BMS_PL with older firmware versions can be updated with BMS_EM hardware. Please contact SOLARMD for more information. | Batteries BMS_PL with older firmware versions can be updated with BMS_EM hardware. Please contact SOLARMD for more information. | ||
- | 2. Minimum Battery Sizing | + | ===== 2. Minimum Battery Sizing |
- | The following information is provided by SOLARMD, it is reproduced here for your convenience and should always be confirmed with the latest | + | |
+ | The following information is provided by Solar MD, it is reproduced here for your convenience and should always be confirmed with the latest | ||
Each battery module is 72Ah (SS4037) or 144Ah (SS4074) at 48V (51.2V nominal). | Each battery module is 72Ah (SS4037) or 144Ah (SS4074) at 48V (51.2V nominal). | ||
- | The following charge rates are managed automatically by the SOLARMD | + | |
+ | The following charge rates are managed automatically by the SolarMD | ||
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the LOGGER V2 triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the LOGGER V2 triggering over-current alarms. | ||
The table below shows the minimum number of battery modules required for the specified inverter/ | The table below shows the minimum number of battery modules required for the specified inverter/ | ||
+ | === Battery Modules Required – per 3.7kWh (SS4037) === | ||
+ | | Phases | Single Phase| Three Phase| Single Phase| Three Phase| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/3000/35 | 1| 3| 1| 3| | ||
+ | | Multiplus 48/5000/70 | 1| 3| 2| 6| | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
+ | === Battery Modules Required – per 7.4kWh (SS202 / SS4074)) === | ||
- | Battery Modules Required – per 3.7kWh (SS4037) | + | ===== 3. CAN Bus Wiring ===== |
- | Phases Single Phase Three Phase Single Phase Three Phase | + | |
- | Inverter/ | + | |
- | Multiplus 48/ | + | |
- | Quattro 48/ | + | |
- | EasySolar 48/ | + | |
- | Battery Modules Required – per 7.4kWh (SS202 / SS4074)) | + | |
+ | Use any UTP cable. Plug 3 of the wires (PIN 7, PIN 8, PIN 3) into the SolarMD LoggerV2. Plug the other side with RJ45 connector into the [[venus-os: | ||
- | 3. CAN Bus Wiring | + | {{: |
- | Use any UTP cable. Plug 3 of the wires into the SOLARMD BMS. Plug the other side with RJ45 connector into the Venus-device. | + | |
- | Then, plug a VE.Can terminator in the other VE.Can socket on the Venus-device alternatively you can use the termination on the Logger V2 side. Two VE.Can terminators are included with the package of the Venus-device as an accessory, only one is used. Keep the other one as a spare. | ||
More information about the cable can be found in its manual. | More information about the cable can be found in its manual. | ||
- | Without properly connecting this cable, the battery will not show up on the display of the Venus-device. | + | |
- | It is important to ensure this connection and display of the battery on the Venus-device display before attempting firmware updates or settings changes on other devices if they depend on the power supply from the battery. It is the LOGGER V2 that signals the battery modules to shut down if the signal from the Venus-device has not been received. | + | Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: |
- | 4. VEConfigure settings | + | |
+ | ===== 4. VEConfigure settings | ||
This section presumes familiarity with VEConfigure software. | This section presumes familiarity with VEConfigure software. | ||
- | 4.1 General tab | + | ==== 4.1 General tab ==== |
- | Check the “Enable battery monitor” function | + | |
- | Set the battery capacity to the total capacity of the battery: eg 72Ah times the number of battery modules for the 3.7 model. | + | * Check the “Enable battery monitor” function |
- | The other parameters (“State of charge when bulk finished” and “Charge efficiency”) can be left to their default setting: They are ignored for a SOLARMD | + | |
+ | ==== 4.2 Charge parameters ==== | ||
+ | In normal operation, the charge parameters are controlled by the SOLARMD LOGGER V2 and communicated through the system by the GX device to the inverter/ | ||
+ | === Charger tab === | ||
+ | ^ VEConfigure Charge Parameter ^ Setting ^ | ||
+ | | Battery type | Lithium | | ||
+ | | Charge curve | Fixed | | ||
+ | | Absorption voltage | 54.6 V | | ||
+ | | Float voltage | 53.4 V | | ||
+ | | Absorption time| 1 Hr | | ||
+ | Note: make sure to double-check the float voltage after completing Assistants, and if necessary, set it back to 53.4 V. | ||
+ | ==== 4.3 Inverter Settings ==== | ||
- | 4.2 Charge parameters | ||
- | In normal operation, the charge parameters are controlled by the SOLARMD LOGGER V2 and communicated through the system by the Venus-device to the inverter/ | ||
- | Charger tab | ||
- | VEConfigure Charge Parameter Setting | ||
- | Battery type Lithium | ||
- | Charge curve Fixed | ||
- | Absorption voltage 55 V | ||
- | Float voltage 53.6 V | ||
- | Absorption time 1 Hr | ||
- | Note: make sure to double check the float voltage after completing Assistants, and if necessary, set it back to 53.4 V. | ||
- | 4.3 Inverter Settings | ||
- | VEConfigure Inverter Parameter Setting | ||
- | DC input low shut-down 47V | ||
- | DC input low restart 51V | ||
- | DC input low pre-alarm* 51V | ||
- | * The pre-alarm setting is dependent on your preference and on site specific requirements. You may wish for this to be activated earlier (eg 53V) in an off grid situation to allow time to start a backup generator. If the system is configured in ESS mode, you may not wish to have this alarm trigger until below the Sustain threshold voltage (eg 49V), as this system is in no danger normally and will ' | ||
+ | ^ VEConfigure Inverter Parameter ^Setting^ | ||
+ | |DC input low shut-down | 47V| | ||
+ | |DC input low restart | 51V| | ||
+ | |DC input low pre-alarm* | 51V| | ||
+ | * The pre-alarm setting is dependent on your preference and on site-specific requirements. You may wish for this to be activated earlier (eg 51V) in an off-grid situation to allow time to start a backup generator. If the system is configured in ESS mode, you may not wish to have this alarm trigger until below the Sustain threshold voltage (eg 50V), as this system is in no danger normally and will ' | ||
- | ESS System Settings | + | ---- |
- | If you are using the battery as part of a grid connected ESS system, please review the ESS Quickstart guide and Design and Installation Manual. | + | |
- | The settings that are specific to the SOLARMD | + | |
+ | === ESS System Settings | ||
+ | If you are using the battery as part of a [[ess: | ||
+ | The settings that are specific to the SolarMD | ||
Select the externally managed Lithium battery option | Select the externally managed Lithium battery option | ||
- | ESS Parameter Settings | + | ^ ESS Parameter |
- | Sustain voltage. 50V | + | |Sustain voltage. |
- | Dynamic cut-off values set all values to 49V. | + | |Dynamic cut-off values |
- | Restart offset: 1.2 V (Default) | + | |Restart offset: |
- | 5. Venus-device and LoggerV2 Configuration | + | |
- | On the Venus-device, go to Settings, System setup: | + | ===== 5. GX device and LoggerV2 Configuration |
- | Venus Settings | + | |
- | DVCC ON | + | On the [[venus-os: |
- | Shared Voltage Sense OFF | + | |
+ | ^Venus Settings | ||
+ | |DVCC|ON| | ||
If you have a VE.Can MPPT, it is advised to use the Venus GX in place of the CCGX. | If you have a VE.Can MPPT, it is advised to use the Venus GX in place of the CCGX. | ||
- | * Select the CAN-bus BMS (500 kbit/s) CAN-profile in the CCGX. Menu path: Settings → Services → CAN-profile. | + | |
- | *On the Solar MD portal (login.mypower24.co.za) Select Victron CAN Translator on CAN2: Menu path: My Devices → Logger → Interfaces →CANBUS2 | + | ---- |
+ | Menu path: | ||
+ | Settings → Services → CAN-profile. | ||
+ | Menu path: | ||
+ | My Devices → Logger → Interfaces → CANBUS2 | ||
- | After properly wiring and setting up, the Battery will be visible as a battery in the device list: | + | * After properly wiring and setting up, the Battery will be visible as a battery in the device list: |
(if you have multiple batteries a single entry will show up, which represents all batteries). | (if you have multiple batteries a single entry will show up, which represents all batteries). | ||
- | The parameters option within the battery page shows the actual battery charge and discharge limits | + | ---- |
+ | * The parameters option within the battery page shows the actual battery charge and discharge limits | ||
This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the SS4037 (3.7 model), the current limit is 100A per module. For example, 140A charge current limit (400 / 100 = 4) means there are 4 SOLARMD battery Batteries connected. | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the SS4037 (3.7 model), the current limit is 100A per module. For example, 140A charge current limit (400 / 100 = 4) means there are 4 SOLARMD battery Batteries connected. | ||
- | Color Control GX Configuration | ||
- | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an Battery battery CAN-bus (500 kbit/s) together on the CCGX. As the SOLARMD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the “Allow to Charge” wire configuration for the MPPT. | ||
- | Venus GX Configuration | + | === Color Control GX Configuration === |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the SOLARMD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). This allows data from the MPPT and SOLARMD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
- | The CAN-bus connections are galvanically isolated at the SOLARMD LOGGER V2. There is no issues using the non-isolated connection of the VGX. | + | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and a Battery battery CAN-bus (500 kbit/s) together on the CCGX. As the SolarMD Logger V2 MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the “Allow to Charge” wire configuration for the MPPT. "Allow to Charge" |
- | 6. VE-Direct MPPT Settings | + | |
- | In normal operation the MPPT charge characteristics are governed by the Venus-device connected to the SOLARMD | + | === Venus GX Configuration |
- | This section presumes familiarity with VictronConnect | + | |
+ | The VGX has two CAN-bus interfaces available. The VE.Can MPPT remain connected to the VE.Can port, while the SOLARMD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). This allows data from the MPPT and SOLARMD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | ||
+ | The CAN-bus connections are galvanically isolated at the SOLARMD LOGGER V2. There are no issues using the non-isolated connection of the VGX. | ||
+ | ===== 6. VE-Direct MPPT Settings | ||
+ | In normal operation, the MPPT charge characteristics are governed by the [[venus-os: | ||
+ | This section presumes familiarity with [[victronconnect: | ||
The settings below are a precautionary measure. | The settings below are a precautionary measure. | ||
- | MPPT Parameter Setting | + | |
- | Battery voltage. 48V | + | ^MPPT Parameter |
- | Absorption voltage 54.6V | + | |Battery voltage. |
+ | |Absorption voltage | ||
battery_compatibility/solar_md.txt · Last modified: 2022-06-18 14:14 by kaloyan
