battery_compatibility:redflow_zbm
| battery_compatibility:redflow_zbm [2016-06-11 10:01] – [Color Control GX] simonhackett | battery_compatibility:redflow_zbm [2021-03-20 02:50] (current) – guystewart | ||
| Line 6: | Line 6: | ||
| * All 48V Multis and Quattros. | * All 48V Multis and Quattros. | ||
| * All 48V solar chargers | * All 48V solar chargers | ||
| - | * Adding a Color Control | + | * Adding a GX device |
| ==== Charge profile ===== | ==== Charge profile ===== | ||
| Line 13: | Line 13: | ||
| - | ===== Color Control | + | ===== GX Device Connect |
| - | Redflow ZBM batteries can be directly interfaced to the CCGX for monitoring and control (see below). | + | Redflow ZBM batteries can be directly interfaced to the GX device (Cerbo GX) for monitoring and control (see below). |
| - | Alternatively one or more ZBM batteries can be used with the Redflow/ | + | Alternatively one or more ZBM batteries can be used with the Redflow/ |
| - | For the direct-attach option, the Color Control | + | For the direct-attach option, the GX device |
| - | - Connect the CCGX to each battery in the system via Modbus-RS485, | + | - Connect the GX device |
| - Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | - Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | ||
| - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | ||
| - | - Configure the battery: the CCGX will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the CCGX, and then connect the next one. Additionally, | + | - Configure the battery: the GX device |
| - | ===== Disqus | + | |
| + | ===== DISQUS | ||
| ~~DISQUS~~ | ~~DISQUS~~ | ||
battery_compatibility/redflow_zbm.1465632063.txt.gz · Last modified: by simonhackett
