battery_compatibility:redflow_zbm
battery_compatibility:redflow_zbm [2016-06-10 23:28] – mvader | battery_compatibility:redflow_zbm [2021-03-20 02:50] (current) – guystewart | ||
====== Victron & Redflow ZBM ====== | ====== Victron & Redflow ZBM ====== | ||
- | http:// | + | http:// |
==== Compatible Victron products ==== | ==== Compatible Victron products ==== | ||
* All 48V Multis and Quattros. | * All 48V Multis and Quattros. | ||
* All 48V solar chargers | * All 48V solar chargers | ||
- | * Adding a Color Control | + | * Adding a GX device |
==== Charge profile ===== | ==== Charge profile ===== | ||
- | - Charge voltage 57.6V (up to 50 Amps per battery, and current per battery self-limits if you limit the voltage) | ||
- | - Linear charge all the way from empty to full (all charge phases are the same - same ‘flat’ voltage). | ||
- | - No need for any sort of battery ‘conditioning’ cycling at all | ||
- | Charger settings: | + | See the information for the Redflow ZCell at https://www.victronenergy.com/ |
- | - Set both absorption and float voltage to 57.6V | + | |
- | - disable storage mode. | + | |
- | - disable bulk protection(?? | + | |
- | - using Assistants, such as the Hub-4 Assistant, is possible but not required. | + | |
- | ===== Color Control GX ===== | ||
- | The Color Control | + | ===== GX Device Connect ===== |
+ | Redflow ZBM batteries can be directly interfaced to the GX device (Cerbo GX) for monitoring and control (see below). | ||
+ | Alternatively one or more ZBM batteries can be used with the Redflow/ | ||
+ | For the direct-attach option, the GX device | ||
- | - Connect the CCGX to each battery in the system via Modbus-RS485, | + | - Connect the GX device |
- Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | - Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | ||
- Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | ||
- | - Configure the battery: the CCGX will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the CCGX, and then connect the next one. Additionally, | + | - Configure the battery: the GX device |
- | ===== Disqus | + | ===== DISQUS |
battery_compatibility/redflow_zbm.txt · Last modified: 2021-03-20 02:50 by guystewart
