battery_compatibility:pylontech_phantom [2019-08-22 11:16] – changed inverter parameter low voltage settings boekel | battery_compatibility:pylontech_phantom [2019-10-26 12:55] – boekel | ||
Line 118: | Line 118: | ||
- | | Battery type | Lithium | | + | | Battery type | Lithium | |
- | Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 53.0 V. | + | Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 51.0 V. |
+ | Note For off-grid use: ignore the 'bms assistant required' | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === |
battery_compatibility/pylontech_phantom.txt · Last modified: 2023-11-13 14:41 by guy_stewart
