battery_compatibility:pylontech_phantom [2019-01-21 10:39] – [DISQUS] ictbeheer | battery_compatibility:pylontech_phantom [2019-02-18 22:06] – guystewart | ||
Line 31: | Line 31: | ||
The minimum required firmware version for the [[https:// | The minimum required firmware version for the [[https:// | ||
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | ||
- | In off-grid systems, the system control functions from the Pylontech Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
=== 1.3 All 48V Multi, MultiPlus, MultiGrid and Quattro are compatible === | === 1.3 All 48V Multi, MultiPlus, MultiGrid and Quattro are compatible === | ||
Line 248: | Line 245: | ||
+ | ~~DISQUS~~ | ||
battery_compatibility/pylontech_phantom.txt · Last modified: 2023-11-13 14:41 by guy_stewart
