battery_compatibility:mgenergysystems
battery_compatibility:mgenergysystems [2019-05-27 13:42] – [Introduction] mscholten | battery_compatibility:mgenergysystems [2021-03-20 02:51] – guystewart | ||
- | [[https:// | + | [[https:// |
Line 19: | Line 19: | ||
- | MG is the only battery system provider that has VE.CAN implemented in the Master BMS. This has the advantage to directly control VE.CAN equipment on this communication bus like VE.CAN MPPT’s and skylla-I’s. Another advantage is that the VE.CAN bus can be connected to the existing NMEA2000 CAN-Bus networks. The default selected mode for the VE.CAN on the GX products (CCGX, Octo GX, Venus GX and CANvu GX) is used. | + | MG is the only battery system provider that has VE.CAN implemented in the Master BMS. This has the advantage to directly control VE.CAN equipment on this communication bus like VE.CAN MPPT’s and skylla-I’s. Another advantage is that the VE.CAN bus can be connected to the existing NMEA2000 CAN-Bus networks. The default selected mode for the VE.CAN on the GX products (Cerbo GX, Octo GX, Venus GX and CANvu GX) is used. |
battery_compatibility/mgenergysystems.txt · Last modified: 2023-09-01 07:26 by guy_stewart
