battery_compatibility:lg_chem_resu
battery_compatibility:lg_chem_resu [2018-06-11 09:51] – guystewart | battery_compatibility:lg_chem_resu [2018-12-06 14:07] – Venus-device links guy_stewart | ||
Line 7: | Line 7: | ||
=== A Venus device is required (either Color Control GX (CCGX) or the VENUS GX) === | === A Venus device is required (either Color Control GX (CCGX) or the VENUS GX) === | ||
- | It is essential to use the CAN-bus connection of the CCGX or VENUS GX with the LG batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | It is essential to use the CAN-bus connection of the [[venus-os: |
The minimum required firmware version for the [[https:// | The minimum required firmware version for the [[https:// | ||
Line 23: | Line 23: | ||
==== Color Control GX or Venus GX required ==== | ==== Color Control GX or Venus GX required ==== | ||
- | To use the LG Chem Resu and Victron equipment, it is necessary to use a CCGX or VenusGX. It takes care of sending the necessary canbus keep-a-live message to the LG Resu. Without it, the LG Resu will open its internal circuitbreaker after 10 minutes. | + | To use the LG Chem Resu and Victron equipment, it is necessary to use a [[venus-os: |
- | Do not attempt firmware updates using the LG Chem battery for power until you can confirm that the battery is connected and showing on the Venus device. | + | Do not attempt firmware updates using the LG Chem battery for power until you can confirm that the battery is connected and showing on the [[venus-os: |
==== Wiring of communication cables ==== | ==== Wiring of communication cables ==== | ||
- | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the LG Chem Resu BMS. Plug the side labeled Victron VE.Can into the Venus-device. | + | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the LG Chem Resu BMS. Plug the side labeled Victron VE.Can into the [[venus-os: |
Then, plug a [[https:// | Then, plug a [[https:// |
battery_compatibility/lg_chem_resu.txt · Last modified: 2019-08-15 12:24 by guy_stewart
