battery_compatibility:lg_chem_resu
battery_compatibility:lg_chem_resu [2017-11-27 10:35] – [Notes] iburger | battery_compatibility:lg_chem_resu [2019-08-15 12:24] (current) – replace venus-device with GX device guy_stewart | ||
==== Compatible Victron products ==== | ==== Compatible Victron products ==== | ||
- | The MultiPlus 48/ | + | The only inverter/ |
+ | === A GX device is required (either Color Control GX (CCGX) or the VENUS GX) === | ||
+ | It is essential to use the CAN-bus connection of the [[venus-os: | ||
+ | The minimum required firmware version for the [[https:// | ||
- | And always a [[https:// | ||
Line 11: | Line 16: | ||
* It can only be used in On-grid systems, for self-consumption. Not for off-grid systems. | * It can only be used in On-grid systems, for self-consumption. Not for off-grid systems. | ||
* Derating, based on the dynamic LG Resu charge- and discharge limits: | * Derating, based on the dynamic LG Resu charge- and discharge limits: | ||
- | * Minimum CCGX version is v1.72 | + | * Minimum CCGX version is v2.15 |
* Actual charge- and discharge limits are visible in the Parameters page. See screenshot below. | * Actual charge- and discharge limits are visible in the Parameters page. See screenshot below. | ||
- | * LG batteries | + | * LG batteries |
* LG battery policy is to only charge the battery to 97% or 98%. It is normal for the battery not to charge to 100%. | * LG battery policy is to only charge the battery to 97% or 98%. It is normal for the battery not to charge to 100%. | ||
+ | ==== GX device required ==== | ||
+ | To use the LG Chem Resu and Victron equipment, it is necessary to use a [[venus-os: | ||
+ | Do not attempt firmware updates using the LG Chem battery for power until you can confirm that the battery is connected and showing on the [[venus-os: | ||
==== Wiring of communication cables ==== | ==== Wiring of communication cables ==== | ||
- | To use the LG Chem Resu and Victron equipment, it is necessary to use a CCGX. It takes care of sending | + | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the LG Chem Resu BMS. Plug the side labeled Victron VE.Can into the [[venus-os: |
- | A special RJ-45 cable is necessary to connect | + | Then, plug a [[https:// |
- | ^ Function ^ VE.Can RJ-45 ^ LG Chem RJ-45 ^ | + | More information about the cable can be found in [[battery_compatibility: |
- | | GND | Pin 3 | Pin 2 | | + | |
- | | CAN-L | + | |
- | | CAN-H | + | |
- | Place a VE.Can terminator in the empty socket | + | Without properly connecting this cable, the battery will stop charging/ |
=== Note on the latest LG Resu models (3.3, 6.5 and 10) === | === Note on the latest LG Resu models (3.3, 6.5 and 10) === | ||
Line 35: | Line 43: | ||
=== General tab === | === General tab === | ||
- Check " | - Check " | ||
- | - Set the battery capacity to 50Ah times the number of battery modules. | ||
- Resu 6.4 - 126 Ah | - Resu 6.4 - 126 Ah | ||
Line 49: | Line 56: | ||
| Battery type | Lithium | | Battery type | Lithium | ||
| Charge curve | Fixed | Fixed | | | Charge curve | Fixed | Fixed | | ||
| Absorption time | 1 Hr | 1 Hr | | | Absorption time | 1 Hr | 1 Hr | | ||
Note: make sure to double check the float voltage after completing Assistants. | Note: make sure to double check the float voltage after completing Assistants. | ||
- | === Hub-4 Assistant === | + | === ESS Assistant === |
Select the fourth battery type: | Select the fourth battery type: | ||
Line 62: | Line 69: | ||
Then: | Then: | ||
- Sustain voltage: 50V | - Sustain voltage: 50V | ||
- | - Do not change the dynamic cut-off values, | + | - The dynamic cut-off values |
- | - Same for the restart offset | + | - Leave the default |
==== Color Control GX Configuration ==== | ==== Color Control GX Configuration ==== | ||
Line 89: | Line 95: | ||
- Restore the battery top cover again. | - Restore the battery top cover again. | ||
- Switch the Multis/ | - Switch the Multis/ | ||
battery_compatibility/lg_chem_resu.txt · Last modified: 2019-08-15 12:24 by guy_stewart
