battery_compatibility:exide
battery_compatibility:exide [2022-07-18 14:17] – [3. Wiring of communication cables] iburger | battery_compatibility:exide [2022-08-15 13:45] (current) – dfaber | ||
- | ====== | + | ====== Victron & Exide ===== |
+ | **This combination depends on Venus OS v2.90 or above, which is scheduled to be released later in 2022. Or the latest beta (see [[ccgx: | ||
The combination of Victron products with the Exide battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | The combination of Victron products with the Exide battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | ||
Compatible models: | Compatible models: | ||
- | * LIBM0480050-G01 as of firmware v1.10 | + | * Sonnenschein Module Pro LIBM0480050-G01 as of firmware v1.10 |
Line 11: | Line 15: | ||
All 48V Multis and Quattros. And always a [[venus-os: | All 48V Multis and Quattros. And always a [[venus-os: | ||
- | === 1.2 Notes === | ||
- | === 1.3 System diagram === | ||
==== 2. GX device needed ==== | ==== 2. GX device needed ==== | ||
Line 21: | Line 21: | ||
==== 3. Wiring of communication cables ==== | ==== 3. Wiring of communication cables ==== | ||
A cable for the CAN-bus connection ships with the battery. This cable has only CAN-L and CAN-H connections and no ground wire. The side of the cable with pins 7 and 8 should be plugged into the | A cable for the CAN-bus connection ships with the battery. This cable has only CAN-L and CAN-H connections and no ground wire. The side of the cable with pins 7 and 8 should be plugged into the | ||
- | [[venus-os: | + | [[venus-os: |
Exide batteries come with a CAN-bus terminator already installed/ | Exide batteries come with a CAN-bus terminator already installed/ | ||
Line 78: | Line 78: | ||
* After properly wiring and setting up, the Exide ESS will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the Exide ESS will be visible as a battery in the device list:{{ : | ||
- | * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ : | + | * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ : |
+ | Next, go to Settings, DVCC, and configure as follows: | ||
+ | ^Venus Settings -> System Setup Parameter ^ Value ^ | ||
+ | |DVCC|ON| | ||
===== 6. MPPT Settings ===== | ===== 6. MPPT Settings ===== | ||
battery_compatibility/exide.txt · Last modified: 2022-08-15 13:45 by dfaber
