battery_compatibility:exide
battery_compatibility:exide [2022-07-18 12:52] – [4. VEConfigure settings] iburger | battery_compatibility:exide [2022-08-15 11:26] – [5. GX device Configuration] iburger | ||
Line 4: | Line 4: | ||
Compatible models: | Compatible models: | ||
- | * LIBM0480050-G01 as of firmware v1.10 | + | * Sonnenschein Module Pro LIBM0480050-G01 as of firmware v1.10 |
Line 11: | Line 13: | ||
All 48V Multis and Quattros. And always a [[venus-os: | All 48V Multis and Quattros. And always a [[venus-os: | ||
- | === 1.2 Notes === | ||
- | === 1.3 System diagram === | ||
==== 2. GX device needed ==== | ==== 2. GX device needed ==== | ||
Line 20: | Line 18: | ||
==== 3. Wiring of communication cables ==== | ==== 3. Wiring of communication cables ==== | ||
- | Use the //VE.Can to CAN-bus | + | A cable for the CAN-bus |
+ | [[venus-os: | ||
Exide batteries come with a CAN-bus terminator already installed/ | Exide batteries come with a CAN-bus terminator already installed/ | ||
- | More information about the cable can be found in [[battery_compatibility: | ||
Without properly connecting this cable, the battery will stop charging/ | Without properly connecting this cable, the battery will stop charging/ | ||
Line 79: | Line 76: | ||
* After properly wiring and setting up, the Exide ESS will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the Exide ESS will be visible as a battery in the device list:{{ : | ||
- | * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ : | + | * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ : |
+ | Next, go to Settings, DVCC, and configure as follows: | ||
+ | ^Venus Settings -> System Setup Parameter ^ Value ^ | ||
+ | |DVCC|ON| | ||
===== 6. MPPT Settings ===== | ===== 6. MPPT Settings ===== | ||
battery_compatibility/exide.txt · Last modified: 2022-08-15 13:45 by dfaber
