battery_compatibility:byd_b-box [2020-03-17 12:30] – guy_stewart | battery_compatibility:byd_b-box [2024-01-22 07:32] (current) – guy_stewart | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | + | | Grid Backup| | |
- | + | | Off-Grid| | |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | ESS | yes| yes| yes| yes| | + | |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Module limit | 32| 32| 12| 64| | + | |
- | | Max capacity| | + | |
- | === 1.1 Offgrid, Backup and Energy Storage Systems | + | === 1.1 Offgrid, Backup and Energy Storage Systems |
Line 27: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | __Special note for Off-Grid systems__ | ||
- | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | + | === 1.2 A GX device is required, eg Cerbo GX, etc === |
- | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: | + | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: |
- | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | + | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: |
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 45: | Line 38: | ||
In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible === | + | When planning |
- | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. | + | |
- | It is recommended | + | |
- | To test operation, try disconnecting the [[venus-os: | + | |
- | __MPPTs with a VE.Can port and VE.Direct port__ | + | |
- | Firmware should be at least version 1.04. | + | |
- | When using VE.Can MPPT' | + | |
- | Please note that older model VE.Can MPPTs (without VE.direct | + | (*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” |
Line 79: | Line 59: | ||
| B-BOX Premium LVL 15.4 | | | B-BOX Premium LVL 15.4 | | ||
BYD also releases firmware update for their BMU and BMS. | BYD also releases firmware update for their BMU and BMS. | ||
Line 86: | Line 68: | ||
Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. On-screen, or via Remote Console on the [[venus-os: | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. On-screen, or via Remote Console on the [[venus-os: | ||
- | BYD Premium | + | BYD B-Box Premium batteries firmware should be no less than V1.4, and the BMS firmware should be no less than V1.3. If necessary, this can be updated automatically via the ethernet port on the BMU when connected to the internet. |
Line 102: | Line 85: | ||
|Phases| | |Phases| | ||
- | | Quattro 48/ | + | | Quattro |
Line 120: | Line 103: | ||
Line 133: | Line 117: | ||
Line 151: | Line 136: | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/ | ||
+ | | MultiPlus, MultiPlus II, MP-II GX, & Quattro-II 48/ | ||
+ | | Quattro 48/ | ||
+ | | Quattro & MultiPlus-II 48/ | ||
- | ===== 3. CANBus Wiring ===== | + | === Battery Modules Required - Premium LV Flex 5.0 === |
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os:start|GX device]]. | + | |Phases| |
+ | | Inverter/Charger | On-Grid | On-Grid | Off-grid | Off-grid | | ||
+ | | MultiPlus 48/500 & 48/ | ||
+ | | MultiPlus 48/1200 & 48/ | ||
+ | | MultiPlus 48/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/3000/35| 1| 3| 2| 4| | ||
- | More information about the cable can be found in [[battery_compatibility: | + | **" |
- | Without properly connecting this cable, the battery | + | The specification for these minimum |
- | It is important to ensure this connection and display of the battery on the [[venus-os:start|GX device]] display before attempting firmware updates or settings changes on other devices if they depend on the power supply from the battery. Without this connection, the battery may turn off unexpectedly. If a reliable DC power supply is required, you can temporarily disconnect the individual BYD battery cells inside their cabinet from the internal Battery Management Unit (BMU). It is the BMU that signals the battery cells to shut down if the signal from the [[venus-os: | + | ===== 3. CAN-Bus wiring between |
+ | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | Without properly connecting this cable, |
- | Using the latest firmware | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery | + | |
- | B-Box relays: | + | |
Line 216: | Line 216: | ||
+ | | Float voltage | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === | ||
Line 250: | Line 254: | ||
- | ===== 5. GX device | + | ===== 5. GX device |
On the [[venus-os: | On the [[venus-os: | ||
Line 258: | Line 262: | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
Line 271: | Line 274: | ||
Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | ||
- | === Color Control GX Configuration === | ||
- | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
=== GX Device with multiple CAN-bus port configuration === | === GX Device with multiple CAN-bus port configuration === | ||
Line 284: | Line 283: | ||
- | ===== 6. VE-Direct | + | === Color Control GX Configuration - Not Recommended |
+ | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can | ||
- | In normal operation | + | For this reason it is recommended to use the Cerbo GX instead. |
- | This section presumes familiarity with [[victronconnect: | + | ===== 6. Solar Charging ===== |
- | The settings below are a precautionary measure. | + | ==== 6.1 Victron MPPT charger settings ==== |
- | ^MPPT Parameter ^ Setting ^ | + | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os: |
+ | |Battery voltage | ||
+ | Therefore it is essential that there is also either a generator or DC MPPT charge controller for overall system stability. If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. | ||
Line 306: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 361: | Line 382: | ||
===== 9. Step by Step Installation Guide ===== | ===== 9. Step by Step Installation Guide ===== | ||
There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | ||
[[https:// | [[https:// | ||
Line 371: | Line 391: | ||
This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
- | A user contributed [[battery_compatibility: | + | ==== Introduction to the new BYD Premium range LVL and LVS ==== |
- | ===== 10. Known Issues ===== | + | |
+ | ===== 10. Known Issues | ||
- | === 10.1 Inaccurate State of Charge (SoC) Readings === | + | === 10.1 Inaccurate State of Charge (SoC) Readings |
Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Line 431: | Line 466: | ||
- | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
- | In a correctly configured | + | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== |
+ | The purpose of this chapter is to serve as reference guide for legacy systems using those two solar charger models. If you have an existing | ||
+ | The Remote On/Off input of the two mentioned solar charger models is used to signal that they can or cannot charge the battery. It needs to be connected to battery positive to enable the charger. Leaving | ||
+ | B-Box relays: | ||
+ | The 'high voltage' | ||
- | If your system | + | 1: If you have 2 or more batteries in your system, |
- | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. | + | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual |
- | ===== 11. Further Information ===== | + | ===== 13. Further Information ===== |
battery_compatibility/byd_b-box.1584444639.txt.gz · Last modified: 2020-03-17 12:30 by guy_stewart
