battery_compatibility:byd_b-box [2025-10-06 06:43] – [Victron & BYD] guy_stewartbattery_compatibility:byd_b-box [2026-10-12 04:01] (current) – guy_stewart
 ====== Victron & BYD ====== ====== Victron & BYD ======
-^  Battery ^  Pro 2.5-10.0 ^  Pro 12.8 & 13.8 ^  L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ LV5.0+ ^
-|  Appearance |  {{ :battery_compatibility:byd-bbox2-5.jpg?nolink&100 |}}|  {{ :battery_compatibility:byd-bbox13-8.jpg?nolink&100 |}}|  {{ :battery_compatibility:byd-l3-5.jpg?nolink&100 |}}| {{:battery_compatibility:byd_premium_lvl.jpg?nolink&150|}}  |  {{:battery_compatibility:byd_lvs.jpg?nolink&80}}  | {{:battery_compatibility:byd_flex.jpg?100|}} | {{:battery_compatibility:byd5.0_.png?100|}} |
-|  ESS |  yes|  yes|  yes|  yes|  yes|  yes|  yes|
-|  Grid Backup|  yes|  yes|  yes |   yes|  yes|  yes|  yes|
-|  Off-Grid|  yes|  yes|  no|  yes|  yes|  yes|  yes|
-|  Module capacity|  2.5 kWh |  13.8 kWh |  3.5 kWh|   15.36 kWh|  4.0 kWh|  5.0 kWh |  5.12 kWh |
-|  Module limit |  32|  32|  12|  64|  64|  64|  32|
-|  Max capacity|  80 kWh|  441.6 kWh|  42 kWh|  983 kWh|  256 kWh|  320 kWh|  163.84 kWh|
 ===== 1. Product & System compatibility ===== ===== 1. Product & System compatibility =====
Line 21: Line 13:
 For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, and factor 1.0 are always important to adhere to, and even more so in case of Off-grid systems. Both BYD and Victron will be reluctant or even refusing to give support to systems that are not sized according to the minimum battery configuration table. For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, and factor 1.0 are always important to adhere to, and even more so in case of Off-grid systems. Both BYD and Victron will be reluctant or even refusing to give support to systems that are not sized according to the minimum battery configuration table.
 +^  Battery ^  Pro 2.5-10.0 ^  Pro 12.8 & 13.8 ^  L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ LV5.0+/LV5.0+ (2026) ^
 +|  Appearance |  {{ :battery_compatibility:byd-bbox2-5.jpg?nolink&100 |}}|  {{ :battery_compatibility:byd-bbox13-8.jpg?nolink&100 |}}|  {{ :battery_compatibility:byd-l3-5.jpg?nolink&100 |}}| {{:battery_compatibility:byd_premium_lvl.jpg?nolink&150|}}  |  {{:battery_compatibility:byd_lvs.jpg?nolink&80}}  | {{:battery_compatibility:byd_flex.jpg?100|}} | {{:battery_compatibility:bydlv.png?120|}} |
 +|  ESS |  yes|  yes|  yes|  yes|  yes|  yes|  yes|
 +|  Grid Backup|  yes|  yes|  yes |   yes|  yes|  yes|  yes|
 +|  Off-Grid|  yes|  yes|  no|  yes|  yes|  yes|  yes|
 +|  Module capacity|  2.5 kWh |  13.8 kWh |  3.5 kWh|   15.36 kWh|  4.0 kWh|  5.0 kWh |  5.12 kWh |
 +|  Module limit |  32|  32|  12|  64|  64|  64|  32|
 +|  Max capacity|  80 kWh|  441.6 kWh|  42 kWh|  983 kWh|  256 kWh|  320 kWh|  163.84 kWh|
 === 1.2 A GX device is required, eg Cerbo GX, etc ===  === 1.2 A GX device is required, eg Cerbo GX, etc ===
Line 44: Line 47:
 Some of our Solar Chargers feature a VE.Direct communication port, some feature a VE.Can communication port, and some feature both. Both of these types of communication ports can be used to connect the Solar charger to the GX Device. Such connection is mandatory, because it is used to regulate charge currents and voltages. Some of our Solar Chargers feature a VE.Direct communication port, some feature a VE.Can communication port, and some feature both. Both of these types of communication ports can be used to connect the Solar charger to the GX Device. Such connection is mandatory, because it is used to regulate charge currents and voltages.
-When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. All other GX Devices can be used, since they have two ports. One can then be used to connect the BYD battery, and the other to connect the Solar Charger.+When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. The Cerbo-S GX also has only one CAN port, so it is not suitable either. Use a GX device with two CAN-bus interfaces, eg Cerbo GX, Venus GX or Ekrano GX. One can then be used to connect the BYD battery, and the other to connect the Solar Charger.
 (*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” and “BlueSolar MPPT 150/85 CAN-bus” which are end-of-life since 2019. Legacy systems, historically installed with this configuration using the allow to charge contacts are not required to make any changes, see the legacy chapter below for details. (*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” and “BlueSolar MPPT 150/85 CAN-bus” which are end-of-life since 2019. Legacy systems, historically installed with this configuration using the allow to charge contacts are not required to make any changes, see the legacy chapter below for details.
Line 61: Line 64:
 | B-BOX Premium LVS 4.0     | | B-BOX Premium LVS 4.0     |
 | B-BOX LV Flex 5.0      | | B-BOX LV Flex 5.0      |
 +| B-BOX LV5.0+/LV5.0+ (2026)      |
 BYD also releases firmware update for their BMU and BMS.  BYD also releases firmware update for their BMU and BMS.
Line 179: Line 183:
 |     EasySolar & EasySolar-II 48/3000/35-50 MPPT150/70|  1|  3|  2|  4| |     EasySolar & EasySolar-II 48/3000/35-50 MPPT150/70|  1|  3|  2|  4|
 |   EasySolar 48/5000/70-100 MPPT150/100|  2|  5|  2|  6| |   EasySolar 48/5000/70-100 MPPT150/100|  2|  5|  2|  6|
 +=== Battery Modules Required - LV5.0+/LV5.0+(2026) ===
 +^ Inverter/Charger ^ Single Phase ^^^ Three Phase ^^^
 +^ ::: ^ On-Grid ^ On-Grid with Backup ^ Off-Grid Inrush Use ^ On-Grid ^ On-Grid with Backup ^ Off-Grid Inrush Use ^
 +| MultiPlus 48/3000/35 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| MultiPlus 48/5000/70 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| MultiPlus-II GX 48/3000/35-32 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| MultiPlus-II GX 48/5000/70-50 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| MultiPlus-II 230V 48/3000/35-32 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| MultiPlus-II 48/4k5/55-32 230V |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥3|
 +| MultiPlus-II 230V 48/5000/70-50 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| MultiPlus-II 48/6k5/100-50 230V |  ≥1|  ≥1|  ≥2|  ≥1|  ≥3|  ≥4|
 +| MultiPlus-II 230V 48/8000/110-100 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| MultiPlus-II 230V 48/10000/140-100 |  ≥1|  ≥2|  ≥2|  ≥1|  ≥5|  ≥5|
 +| MultiPlus-II 230V 48/15000/200-100 |  ≥1|  ≥2|  ≥2|  ≥1|  ≥6|  ≥6|
 +| MultiPlus-II 24/3000/70-32 GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| MultiPlus-II 48/3000/35-32 230V GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| MultiPlus-II 48/5000/70-50 230V GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| MultiPlus-II 48/4k5/55-32 230V GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥3|
 +| MultiPlus-II 48/6k5/100-50 230V GX |  ≥1|  ≥1|  ≥2|  ≥1|  ≥3|  ≥4|
 +| Multi RS Solar 48/6000 Dual Tracker |  ≥1|  ≥3|  ≥3|  ≥1|  ≥10|  ≥10|
 +| Quattro 48/5000/70-100/100 |  ≥1|  ≥2|  ≥2|  ≥1|  ≥2|  ≥3|
 +| Quattro 48/8000/110-100/100 |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| Quattro 48/10000/140-100/100 |  ≥1|  ≥2|  ≥2|  ≥1|  ≥5|  ≥5|
 +| Quattro 48/15000/200-100/100 |  ≥1|  ≥2|  ≥2|  ≥1|  ≥6|  ≥6|
 +| Quattro-II 48/5000/70-50 |  ≥1|  ≥3|  ≥3|  ≥1|  ≥10|  ≥10|
 +| EasySolar-II 48/3000/35-32 MPPT 250/70 GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥2|
 +| EasySolar-II 24/3000/70-32 MPPT 250/70 GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| EasySolar-II 48/5000/70-50 MPPT 250/100 GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥3|  ≥3|
 +| EasySolar-II 48/4k5/55-32 MPPT 250/70 GX |  ≥1|  ≥1|  ≥1|  ≥1|  ≥2|  ≥3|
 +| EasySolar-II 48/6k5/100-50 MPPT 250/100 GX |  ≥1|  ≥1|  ≥2|  ≥1|  ≥3|  ≥4|
 +| Battery firmware: BMS ≥1.2; GX firmware ≥V3.20 |||||||
Line 308: Line 345:
 Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down.   Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down.
-===== 7. Example Wiring Diagram =====+===== 7. Example Wiri
 +ng Diagram =====
 {{:battery_compatibility:byd-example-diagram-2018-07-21.png?direct&800|}} {{:battery_compatibility:byd-example-diagram-2018-07-21.png?direct&800|}}
Line 337: Line 375:
 If its not visible, check: If its not visible, check:
-  * [[venus-os:start|GX device]] firmware version (update to latest version, v2.15 or later)+  * [[venus-os:start|GX device]] firmware version (update to the latest version; section 1.2 gives the minimum)
   * BYD firmware version (see requirement above)   * BYD firmware version (see requirement above)
   * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work.   * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work.
Line 380: Line 418:
 In general the ARM LED on the battery module has these meanings: In general the ARM LED on the battery module has these meanings:
-  * Could be a temporary issue, that corrects self automatically after a short while (matter of minutes).+  * Could be a temporary issue, that corrects self automatically after a short
 + while (matter of minutes).
   * Could be an external issue, unacceptable voltage or current.   * Could be an external issue, unacceptable voltage or current.
Line 534: Line 573:
-===== DISQUS ===== +
-~~DISQUS~~+
battery_compatibility/byd_b-box.1759733027.txt.gz · Last modified: by guy_stewart
