battery_compatibility:byd_b-box [2022-08-18 09:29] – guystewart | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
Line 490: | Line 490: | ||
===== 12. High voltage warning or alarm shown on battery status ===== | ===== 12. High voltage warning or alarm shown on battery status ===== | ||
- | The 'high voltage' | + | The 'high voltage' |
+ | To help the batteries balance quickly, keep the batteries fully charged | ||
If you are unable to maintain the target voltage to balance the batteries without the 'high voltage' | If you are unable to maintain the target voltage to balance the batteries without the 'high voltage' | ||
Line 496: | Line 512: | ||
- | If it is not possible to raise the voltage over time, and eventually disable | + | If it is not possible to raise the voltage |
- | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. | + | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. |
- | 2: Contact your dealer for further assistance (they can provide additional software to see individual cell level data), or assist with other potential solutions. | + | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed |
===== 13. Further Information ===== | ===== 13. Further Information ===== |
