battery_compatibility:byd_b-box [2021-12-14 06:53] – [2. Minimum Battery Sizing] guystewart | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
Line 318: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 479: | Line 488: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
- | ===== 12. Further Information ===== | + | ===== 13. Further Information ===== |
