battery_compatibility:byd_b-box [2021-11-24 06:42] – guystewart | battery_compatibility:byd_b-box [2022-08-18 09:29] – guystewart | ||
Line 90: | Line 90: | ||
| Multiplus & Multiplus II & MP-II GX 48/ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
Line 104: | Line 105: | ||
Line 117: | Line 119: | ||
Line 135: | Line 138: | ||
Line 149: | Line 153: | ||
Line 162: | Line 167: | ||
|Phases| | |Phases| | ||
- | | Multiplus & Multiplus II & MP-II GX 48/ | + | | Multiplus 48/500 & 48/ |
- | | Multiplus & Multiplus II & MP-II GX 48/ | + | | Multiplus 48/1200 & 48/ |
- | | | + | | Multiplus 48/ |
- | | Quattro 48/ | + | | Multiplus & Multiplus II & MP-II GX 48/ |
- | | Quattro 48/ | + | | Inverter RS & Multi RS 48/ |
- | | | + | | Quattro 48/ |
+ | | Quattro 48/ | ||
Line 175: | Line 184: | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 310: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 471: | Line 488: | ||
+ | The 'high voltage' | ||
+ | If it is not possible to raise the voltage over time, and eventually disable this manual override: | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. | ||
+ | 2: Contact your dealer for further assistance (they can provide additional software to see individual cell level data), or assist with other potential solutions. | ||
- | ===== 12. Further Information ===== | + | ===== 13. Further Information ===== |
