battery_compatibility:byd_b-box [2021-11-24 06:42] – guystewart | battery_compatibility:byd_b-box [2022-05-23 15:40] – [8. Troubleshooting] guystewart | ||
Line 90: | Line 90: | ||
| Multiplus & Multiplus II & MP-II GX 48/ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
Line 104: | Line 105: | ||
Line 117: | Line 119: | ||
Line 135: | Line 138: | ||
Line 149: | Line 153: | ||
Line 162: | Line 167: | ||
|Phases| | |Phases| | ||
- | | Multiplus & Multiplus II & MP-II GX 48/ | + | | Multiplus 48/500 & 48/ |
- | | Multiplus & Multiplus II & MP-II GX 48/ | + | | Multiplus 48/1200 & 48/ |
- | | | + | | Multiplus 48/ |
- | | Quattro 48/ | + | | Multiplus & Multiplus II & MP-II GX 48/ |
- | | Quattro 48/ | + | | Inverter RS & Multi RS 48/ |
- | | | + | | Quattro 48/ |
+ | | Quattro 48/ | ||
Line 175: | Line 184: | ||
The specification for these minimum battery sizes was obtained from [[http:// | The specification for these minimum battery sizes was obtained from [[http:// | ||
===== 3. CAN-Bus wiring between the battery and GX Device ===== | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
Line 310: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
=== Step 1. Check that the BYD battery is visible on the GX device list === | === Step 1. Check that the BYD battery is visible on the GX device list === |
