battery_compatibility:byd_b-box [2021-04-08 16:04] – [4. VEConfigure settings] added abs. voltage offgrid 56,5V (prevent frequency lock) boekel | battery_compatibility:byd_b-box [2021-08-18 08:44] – guystewart | ||
Line 28: | Line 28: | ||
When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 193: | Line 193: | ||
- | | Absorption voltage off-grid systems | 56.5 V | | + | | Absorption voltage off-grid systems |
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === |
