battery_compatibility:byd_b-box [2020-02-27 10:08] – [1. Product & System compatibility] guystewart | battery_compatibility:byd_b-box [2020-04-20 14:52] – [9. Step by Step Installation Guide] guy_stewart | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | | ESS | yes| yes| yes| yes| yes| |
- | + | | Grid Backup| | |
- | + | | Off-Grid| | |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | + | | Module limit | 32| 32| 12| 64| 64| |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Max capacity| | + | |
Line 27: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | ||
- | === 1.2 A GX device is required, eg Color Control GX (CCGX), Venus GX (VGX), etc === | + | When used with B-Box Pro series |
- | It is essential to use the CAN-bus connection of a [[venus-os: | + | |
- | When used with B-Box batteries, the minimum supported firmware version for the [[venus-os: | + | |
Line 45: | Line 34: | ||
In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar | + | When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. All other GX Devices can be used, since they have two ports. One can then be used to connect the BYD battery, |
- | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. | + | (*) with exception of the models “BlueSolar |
- | It is recommended to use the MPPTs with VE.Direct port with BYD batteries. | + | |
- | To test operation, try disconnecting the [[venus-os: | + | |
- | __MPPTs | + | |
- | Firmware should be at least version 1.04. | + | |
- | When using VE.Can MPPT' | + | |
- | Please note that older model VE.Can MPPTs (without VE.direct and with built in screen) are no longer supported with BYD managed batteries. | + | |
Line 78: | Line 54: | ||
+ | | B-BOX Premium LVS 3.8 | | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | |
- | On-screen, or via Remote Console on the [[venus-os:start|GX device]], this version is named v4.13. | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | Batteries with older firmware versions can be updated. Please contact BYD for more information. | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. On-screen, or via Remote Console on the [[venus-os: |
Line 92: | Line 69: | ||
The following charge rates are managed automatically by the BYD BMU and [[venus-os: | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | ||
Line 102: | Line 79: | ||
|Phases| | |Phases| | ||
Line 147: | Line 123: | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/ | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
+ | === Battery Modules Required - Premium LVS 3.8 === | ||
+ | |Phases| | ||
- | ===== 3. CANBus Wiring | + | **" |
+ | The specification for these minimum battery sizes was obtained from [[http:// | ||
+ | ===== 3. CAN-Bus wiring between the battery and GX Device | ||
Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
Line 164: | Line 167: | ||
Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: | Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: | ||
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | |
- | Using the latest firmware on all devices, the BYD allow to charge contacts are only required when using VE.Can MPPT' | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | + | |
- | B-Box relays: | + | |
Line 237: | Line 222: | ||
- | ===== 5. GX device | + | ===== 5. GX device |
On the [[venus-os: | On the [[venus-os: | ||
Line 245: | Line 230: | ||
* Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | ||
Line 271: | Line 255: | ||
- | ===== 6. VE-Direct MPPT Settings | + | ===== 6. Solar Charging |
- | In normal operation the MPPT charge characteristics are governed by the [[venus-os: | + | ==== 6.1 Victron MPPT charger settings ==== |
- | This section presumes familiarity with [[victronconnect:start|VictronConnect]] | + | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os:start|GX device]]. The settings below are a precautionary measure only: |
- | The settings below are a precautionary measure. | + | ^ MPPT Parameter ^ Setting ^ |
- | + | |Battery voltage | |
- | ^MPPT Parameter ^ Setting ^ | + | |
+ | If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | ||
Line 348: | Line 339: | ||
===== 9. Step by Step Installation Guide ===== | ===== 9. Step by Step Installation Guide ===== | ||
There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | ||
[[https:// | [[https:// | ||
Line 358: | Line 348: | ||
This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
- | A user contributed [[battery_compatibility: | + | ==== Introduction to the new BYD Premium range LVL and LVS ==== |
- | ===== 10. Known Issues ===== | + | |
+ | ===== 10. Known Issues | ||
- | === 10.1 Inaccurate State of Charge (SoC) Readings === | + | === 10.1 Inaccurate State of Charge (SoC) Readings |
Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Line 418: | Line 417: | ||
- | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
- | In a correctly configured system, the inverter will shut itself down before the batteries enter a self protective shut down state. | + | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== |
- | If your system | + | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. Which for all modern models |
+ | The Remote On/Off input of the two mentioned solar charger models | ||
+ | B-Box relays: | ||
+ | * Relay T1-T2: closed if allowed | ||
- | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. | ||
- | ===== 11. Further Information ===== | + | ===== 12. Further Information ===== |
