battery_compatibility:byd_b-box [2019-10-30 12:14] – [5. GX device Configuration] guy_stewart | battery_compatibility:byd_b-box [2020-02-11 13:05] – [5. GX device Configuration] guy_stewart | ||
Line 33: | Line 33: | ||
It is essential to use the CAN-bus connection of a [[venus-os: | It is essential to use the CAN-bus connection of a [[venus-os: | ||
- | When used with B-Box batteries, the minimum | + | When used with B-Box batteries, the minimum |
- | The minimum firmware version is 422. Though updating | + | The minimum |
These inverter/ | These inverter/ | ||
Line 55: | Line 55: | ||
The MPPT requires connection to the [[venus-os: | The MPPT requires connection to the [[venus-os: | ||
To test operation, try disconnecting the [[venus-os: | To test operation, try disconnecting the [[venus-os: | ||
- | __MPPTs with a VE.Can port__ | + | __MPPTs with a VE.Can |
- | Firmware should be at least version | + | Firmware should be at least version |
- | When using VE.Can MPPT' | + | |
+ | When using VE.Can MPPT' | ||
+ | Please note that older model VE.Can MPPTs (without VE.direct and with built in screen) are no longer supported with BYD managed batteries. | ||
Line 255: | Line 255: | ||
- | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the charge current limit is 35A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. | + | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the charge current limit is ~35-50 A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. |
- | Note the discharge current limit figure | + | |
+ | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | ||
Line 262: | Line 263: | ||
The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
- | === Venus GX Configuration | + | === GX Device with multiple CAN-bus port configuration |
+ | With GX devices that have two CAN-bus interfaces available (eg Cerbo GX and Venus GX), the VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND), or BMS-Can ports. | ||
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | This allows data from the MPPT and BYD battery simultaneously. |
- | This allows data from the MPPT and BYD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
The CAN-bus connections are galvanically isolated at the BYD BMU. There is no issues using the non-isolated connection of the VGX. | The CAN-bus connections are galvanically isolated at the BYD BMU. There is no issues using the non-isolated connection of the VGX. |
