battery_compatibility:byd_b-box [2019-10-09 01:56] – [9. Step by Step Installation Guide] guy_stewart | battery_compatibility:byd_b-box [2022-09-01 04:25] – [12. High voltage warning or alarm shown on battery status] guystewart | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | + | | Grid Backup| | |
- | + | | Off-Grid| | |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Max capacity| | + | |
- | === 1.1 Offgrid, Backup and Energy Storage Systems | + | === 1.1 Offgrid, Backup and Energy Storage Systems |
Line 27: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | __Special note for Off-Grid systems__ | ||
- | === 1.2 A GX device is required, eg Color Control | + | === 1.2 A GX device is required, eg Cerbo GX, etc === |
- | It is essential to use the CAN-bus connection of a [[venus-os: | + | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: |
- | When used with B-Box batteries, the minimum | + | When used with B-Box Pro series |
- | === 1.3 All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
- | The minimum firmware version is 422. Though updating | + | The minimum |
These inverter/ | These inverter/ | ||
Line 45: | Line 38: | ||
In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible === | + | When planning |
- | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. | + | |
- | It is recommended | + | |
- | To test operation, try disconnecting the [[venus-os:start|GX device]] from the MPPT. After a time-out, the MPPT will stop charging and flash an error code on its LEDs. The error code is [[https:// | + | |
- | __MPPTs with a VE.Can | + | |
- | Firmware should be at least version 2.05. | + | |
- | When using VE.Can MPPT's, it is recommended to use the Venus GX (VGX), instead of the CCGX. The VGX has two CAN-bus interfaces available and allows communication between | + | |
Line 78: | Line 58: | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | On-screen, or via Remote Console on the [[venus-os: | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. |
- | Batteries with older firmware versions can be updated. Please contact BYD for more information. | + | |
The following charge rates are managed automatically by the BYD BMU and [[venus-os: | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | ||
Line 102: | Line 85: | ||
|Phases| | |Phases| | ||
- | | Multiplus 48/ | + | | Multiplus |
Line 120: | Line 103: | ||
Line 133: | Line 117: | ||
Line 147: | Line 132: | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
+ | |Phases| | ||
- | ===== 3. CANBus Wiring ===== | + | === Battery Modules Required - Premium LV Flex 5.0 === |
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os:start|GX device]]. | + | |Phases| |
+ | | Inverter/Charger | On-Grid | On-Grid | Off-grid | Off-grid | | ||
+ | | Multiplus 48/500 & 48/800| 1| 1| 1| 1| | ||
+ | | Multiplus 48/1200 & 48/ | ||
+ | | Multiplus 48/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/3000/35| | ||
- | More information about the cable can be found in [[battery_compatibility: | + | **" |
- | Without properly connecting this cable, the battery | + | The specification for these minimum |
- | It is important to ensure this connection and display of the battery on the [[venus-os:start|GX device]] display before attempting firmware updates or settings changes on other devices if they depend on the power supply from the battery. Without this connection, the battery may turn off unexpectedly. If a reliable DC power supply is required, you can temporarily disconnect the individual BYD battery cells inside their cabinet from the internal Battery Management Unit (BMU). It is the BMU that signals the battery cells to shut down if the signal from the [[venus-os: | + | ===== 3. CAN-Bus wiring between |
+ | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | Without properly connecting this cable, |
- | Using the latest firmware | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery | + | |
- | B-Box relays: | + | |
Line 203: | Line 216: | ||
+ | | Float voltage | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === | ||
Line 237: | Line 254: | ||
- | ===== 5. GX device | + | ===== 5. GX device |
On the [[venus-os: | On the [[venus-os: | ||
Line 245: | Line 262: | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
Line 255: | Line 271: | ||
- | Note this figure has been increased in recent firmware versions - so it may appear slightly higher (eg 40A per cell). | + | |
- | === Color Control GX Configuration === | + | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. |
- | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | + | |
- | === Venus GX Configuration | + | === GX Device with multiple CAN-bus port configuration |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | With GX devices that have two CAN-bus interfaces available |
- | This allows data from the MPPT and BYD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
+ | This allows data from the MPPT and BYD battery simultaneously. | ||
- | ===== 6. VE-Direct | + | === Color Control GX Configuration - Not Recommended |
+ | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can | ||
- | In normal operation | + | For this reason it is recommended to use the Cerbo GX instead. |
- | This section presumes familiarity with [[victronconnect: | + | ===== 6. Solar Charging ===== |
- | The settings below are a precautionary measure. | + | ==== 6.1 Victron MPPT charger settings ==== |
- | ^MPPT Parameter ^ Setting ^ | + | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os: |
+ | |Battery voltage | ||
+ | Therefore it is essential that there is also either a generator or DC MPPT charge controller for overall system stability. If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. | ||
Line 291: | Line 318: | ||
+ | The GX device | ||
+ | If instead | ||
Line 346: | Line 382: | ||
===== 9. Step by Step Installation Guide ===== | ===== 9. Step by Step Installation Guide ===== | ||
There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | ||
[[https:// | [[https:// | ||
Line 356: | Line 391: | ||
This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
- | A user contributed [[battery_compatibility: | + | ==== Introduction to the new BYD Premium range LVL and LVS ==== |
- | ===== 10. Known Issues ===== | + | |
+ | ===== 10. Known Issues | ||
- | === 10.1 Inaccurate State of Charge (SoC) Readings === | + | === 10.1 Inaccurate State of Charge (SoC) Readings |
Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Line 416: | Line 466: | ||
- | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
- | In a correctly configured | + | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== |
+ | The purpose of this chapter is to serve as reference guide for legacy systems using those two solar charger models. If you have an existing | ||
+ | The Remote On/Off input of the two mentioned solar charger models is used to signal that they can or cannot charge the battery. It needs to be connected to battery positive to enable the charger. Leaving | ||
+ | B-Box relays: | ||
+ | The 'high voltage' | ||
- | If your system | + | 1: If you have 2 or more batteries in your system, |
- | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. | + | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual |
- | ===== 11. Further Information ===== | + | ===== 13. Further Information ===== |
