battery_compatibility:byd_b-box [2019-08-15 11:37] – replaced Venus-device with GX device guy_stewart | battery_compatibility:byd_b-box [2020-11-20 13:01] – [1. Product & System compatibility] guy_stewart | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | | ESS | yes| yes| yes| yes| yes| |
- | + | | Grid Backup| | |
- | + | | Off-Grid| | |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | + | | Module limit | 32| 32| 12| 64| 64| |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Max capacity| | + | |
Line 27: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | ||
- | === 1.2 A GX device is required, eg Color Control GX (CCGX), Venus GX (VGX), etc === | + | When used with B-Box Pro series |
- | It is essential to use the CAN-bus connection of a [[venus-os: | + | |
- | When used with B-Box batteries, the minimum | + | |
- | The minimum firmware version is 422. Though updating | + | The minimum |
These inverter/ | These inverter/ | ||
Line 45: | Line 34: | ||
In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible === | + | When planning |
- | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. | + | |
- | It is recommended | + | |
- | To test operation, try disconnecting the [[venus-os:start|GX device]] from the MPPT. After a time-out, the MPPT will stop charging and flash an error code on its LEDs. The error code is [[https:// | + | |
- | __MPPTs with a VE.Can | + | |
- | Firmware should be at least version 2.05. | + | |
- | When using VE.Can MPPT's, it is recommended to use the Venus GX (VGX), instead of the CCGX. The VGX has two CAN-bus interfaces available and allows communication between | + | |
Line 78: | Line 54: | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | |
- | On-screen, or via Remote Console on the [[venus-os:start|GX device]], this version is named v4.13. | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | Batteries with older firmware versions can be updated. Please contact BYD for more information. | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. On-screen, or via Remote Console on the [[venus-os: |
The following charge rates are managed automatically by the BYD BMU and [[venus-os: | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | ||
Line 102: | Line 80: | ||
|Phases| | |Phases| | ||
Line 147: | Line 124: | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/ | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
+ | |Phases| | ||
- | ===== 3. CANBus Wiring | + | **" |
+ | The specification for these minimum battery sizes was obtained from [[http:// | ||
+ | ===== 3. CAN-Bus wiring between the battery and GX Device | ||
Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
Line 164: | Line 168: | ||
Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: | Without properly connecting this cable, the battery will not show up on the display of the [[venus-os: | ||
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | |
- | Using the latest firmware on all devices, the BYD allow to charge contacts are only required when using VE.Can MPPT' | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | + | |
- | B-Box relays: | + | |
Line 237: | Line 223: | ||
- | ===== 5. GX device | + | ===== 5. GX device |
On the [[venus-os: | On the [[venus-os: | ||
Line 245: | Line 231: | ||
* Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | ||
Line 255: | Line 240: | ||
- | Note this figure has been increased in recent | + | |
+ | Note these limits have been adjusted higher by BYD during | ||
- | The CCGX only has one available VE.Can | + | The CCGX only has one available VE.Can |
- | === Venus GX Configuration | + | === GX Device with multiple CAN-bus port configuration |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | With GX devices that have two CAN-bus interfaces available |
- | This allows data from the MPPT and BYD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
+ | This allows data from the MPPT and BYD battery simultaneously. | ||
- | ===== 6. VE-Direct MPPT Settings | + | ===== 6. Solar Charging |
- | In normal operation the MPPT charge characteristics are governed by the [[venus-os: | + | ==== 6.1 Victron MPPT charger settings ==== |
- | This section presumes familiarity with [[victronconnect:start|VictronConnect]] | + | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os:start|GX device]]. The settings below are a precautionary measure only: |
- | The settings below are a precautionary measure. | + | ^ MPPT Parameter ^ Setting ^ |
- | + | |Battery voltage | |
- | ^MPPT Parameter ^ Setting ^ | + | |
+ | If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | ||
Line 346: | Line 340: | ||
- | ===== 9. Step by Step Guide ===== | ||
- | If you need further details, a user contributed [[battery_compatibility: | + | ===== 9. Step by Step Installation Guide ===== |
- | ===== 10. Known Issues ===== | + | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// |
- | === 10.1 Inaccurate State of Charge (SoC) Readings === | + | [[https:// |
+ | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
+ | ==== Introduction to the new BYD Premium range LVL and LVS ==== | ||
+ | ===== 10. Known Issues with B-Box Pro models ===== | ||
+ | === 10.1 Inaccurate State of Charge (SoC) Readings | ||
Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Line 409: | Line 418: | ||
- | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
- | In a correctly configured system, the inverter will shut itself down before the batteries enter a self protective shut down state. | + | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== |
- | If your system | + | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. Which for all modern models |
+ | The Remote On/Off input of the two mentioned solar charger models | ||
+ | B-Box relays: | ||
+ | * Relay T1-T2: closed if allowed | ||
- | Even a single 100/20 48V MPPT charger unit with 2 x 60 cell solar panels would be sufficient to add this self correcting mechanism able to maintain the DC bus voltage and improve longterm system reliability considerably from accidental deep discharge and subsequent shut down. | ||
- | ===== 11. Further Information ===== | + | ===== 12. Further Information ===== |
