battery_compatibility:byd_b-box [2019-02-18 14:08] – guy_stewart | battery_compatibility:byd_b-box [2019-10-30 12:14] – [5. GX device Configuration] guy_stewart | ||
The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | ||
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: |
Line 29: | Line 29: | ||
- | === 1.2 A Venus-device is required, | + | === 1.2 A GX device is required, |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | It is essential to use the CAN-bus connection of a [[venus-os: |
- | When used with B-Box batteries, the minimum required firmware version for the [[https:// | + | When used with B-Box batteries, the minimum required firmware version for the [[venus-os:start|GX device]] is v2.15. It is highly recommended to use the latest firmware version on all connected devices, including CCGX/VGX, Inverter/ |
Line 39: | Line 39: | ||
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | + | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: |
- | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | + | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: |
Line 55: | Line 55: | ||
Line 83: | Line 83: | ||
Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | ||
- | On-screen, or via Remote Console on the [[venus-os: | + | On-screen, or via Remote Console on the [[venus-os: |
Batteries with older firmware versions can be updated. Please contact BYD for more information. | Batteries with older firmware versions can be updated. Please contact BYD for more information. | ||
Line 94: | Line 94: | ||
Each battery cell is approximately 50Ah at 48V (51.2V nominal). | Each battery cell is approximately 50Ah at 48V (51.2V nominal). | ||
- | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | + | The following charge rates are managed automatically by the BYD BMU and [[venus-os: |
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | ||
Line 156: | Line 156: | ||
===== 3. CANBus Wiring ===== | ===== 3. CANBus Wiring ===== | ||
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | + | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: |
Line 195: | Line 195: | ||
=== 4.2 Charge parameters === | === 4.2 Charge parameters === | ||
- | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: | + | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: |
Line 237: | Line 237: | ||
- | ===== 5. Venus-device Configuration ===== | + | ===== 5. GX device Configuration ===== |
Line 255: | Line 255: | ||
- | Note this figure has been increased in recent | + | Note the discharge current limit figure has been increased in 2019 firmware versions - so it may appear slightly higher (eg 50A per cell). |
Line 271: | Line 271: | ||
- | In normal operation the MPPT charge characteristics are governed by the [[venus-os: | + | In normal operation the MPPT charge characteristics are governed by the [[venus-os: |
Line 289: | Line 289: | ||
- | As a safety precaution, the inverter/ | + | As a safety precaution, the inverter/ |
- | You can then start the inverter/ | + | You can then start the inverter/ |
- | === Step 1. Check that the BYD battery is visible on the Venus-device list === | + | === Step 1. Check that the BYD battery is visible on the GX device list === |
Line 301: | Line 301: | ||
* BYD firmware version (see requirement above) | * BYD firmware version (see requirement above) | ||
* CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | ||
Line 308: | Line 308: | ||
=== Step 2. Check that the BYD battery is ready for use === | === Step 2. Check that the BYD battery is ready for use === | ||
When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | ||
Line 346: | Line 346: | ||
- | ===== 9. Step by Step Guide ===== | + | ===== 9. Step by Step Installation |
- | If you need further details, | + | There is a step by step installation |
+ | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
===== 10. Known Issues ===== | ===== 10. Known Issues ===== | ||
=== 10.1 Inaccurate State of Charge (SoC) Readings === | === 10.1 Inaccurate State of Charge (SoC) Readings === | ||
- | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | + | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: |
Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | ||
Line 368: | Line 375: | ||
=== Work-arounds === | === Work-arounds === | ||
- | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: | + | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: |
The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | ||
