battery_compatibility:byd_b-box [2019-02-12 21:33] – guystewart | battery_compatibility:byd_b-box [2019-03-16 06:38] – guy_stewart | ||
Line 29: | Line 29: | ||
- | === 1.2 A Venus-device is required, | + | === 1.2 A Venus-device is required, |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | It is essential to use the CAN-bus connection of a [[venus-os: |
- | When used with B-Box batteries, the minimum required firmware version for the [[https:// | + | When used with B-Box batteries, the minimum required firmware version for the [[venus-os:start|Venus-device]] is v2.15. It is highly recommended to use the latest firmware version on all connected devices, including CCGX/VGX, Inverter/ |
Line 55: | Line 55: | ||
The MPPT requires connection to the [[venus-os: | The MPPT requires connection to the [[venus-os: | ||
Line 256: | Line 256: | ||
This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the current limit is 35A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the current limit is 35A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. | ||
+ | Note this figure has been increased in recent firmware versions - so it may appear slightly higher (eg 40A per cell). | ||
Line 313: | Line 314: | ||
- | Also check that your are seeing the expected | + | Also check that your are seeing the expected |
Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | ||
Line 407: | Line 408: | ||
+ | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
+ | If your system is supplied only with AC-bus solar charging, this may prevent the solar inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | ||
===== 11. Further Information ===== | ===== 11. Further Information ===== | ||
Line 416: | Line 426: | ||
