battery_compatibility:byd_b-box [2019-01-22 10:16] – external edit 127.0.0.1 | battery_compatibility:byd_b-box [2024-01-22 07:32] (current) – guy_stewart | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | | ESS | yes| yes| yes| yes| yes| yes| |
- | + | | Grid Backup| | |
- | + | | Off-Grid| | |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | + | | Module limit | 32| 32| 12| 64| 64| 64| |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Max capacity| | + | |
- | === 1.1 Offgrid, Backup and Energy Storage Systems | + | === 1.1 Offgrid, Backup and Energy Storage Systems |
Line 27: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | __Special note for Off-Grid systems__ | ||
- | === 1.2 A Venus-device is required, | + | === 1.2 A GX device is required, |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | |
- | When used with B-Box batteries, the minimum required firmware version for the [[https:// | + | |
- | === 1.3 All 48V Multis, MultiPlusses, | + | |
- | The minimum firmware version is 422. Though updating to the latest firmware is recommended where possible. | + | |
- | These inverter/ | + | |
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | + | |
- | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | + | |
+ | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar | + | === 1.3 All 48V Multis, MultiPlusses, |
- | For proper operation, the B-Box battery needs to be able to control | + | The minimum supported firmware version is 469. Updating |
- | It is recommended | + | |
- | __MPPTs with a VE.Direct port__ | + | These inverter/ |
- | MPPTs are controlled via the [[venus-os: | + | In grid connected systems, advanced control functions |
- | The MPPT requires connection to the [[venus-os: | + | In off-grid systems, |
- | To test operation, try disconnecting | + | |
- | __MPPTs with a VE.Can port__ | + | === 1.4 Solar Charger compatibility === |
- | Firmware should be at least version 2.05. | + | All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible (*). |
- | When using VE.Can | + | Some of our Solar Chargers feature a VE.Direct communication port, some feature a VE.Can |
+ | When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. All other GX Devices can be used, since they have two ports. One can then be used to connect the BYD battery, and the other to connect the Solar Charger. | ||
Line 78: | Line 58: | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | On-screen, or via Remote Console on the [[venus-os: | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. |
- | Batteries with older firmware versions can be updated. Please contact BYD for more information. | + | |
- | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | + | The following charge rates are managed automatically by the BYD BMU and [[venus-os: |
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | ||
Line 102: | Line 85: | ||
|Phases| | |Phases| | ||
- | | Quattro 48/ | + | | Quattro |
Line 120: | Line 103: | ||
Line 133: | Line 117: | ||
Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | ||
- | Up to 5 L modules can be installed per L series BCU; 6 or more will require additional BCU. | + | Up to 4 L modules can be installed per L series BCU; 5 or more will require additional BCU. |
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/ | ||
+ | | MultiPlus, MultiPlus II, MP-II GX, & Quattro-II 48/ | ||
+ | | Quattro 48/ | ||
+ | | Quattro & MultiPlus-II 48/ | ||
+ | | EasySolar 48/ | ||
+ | |Phases| | ||
- | ===== 3. CANBus Wiring ===== | + | === Battery Modules Required - Premium LV Flex 5.0 === |
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os:start|Venus-device]]. | + | |Phases| |
+ | | Inverter/Charger | On-Grid | On-Grid | Off-grid | Off-grid | | ||
+ | | MultiPlus 48/500 & 48/ | ||
+ | | MultiPlus 48/1200 & 48/ | ||
+ | | MultiPlus 48/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/3000/35| 1| 3| 2| 4| | ||
+ | | MultiPlus, MultiPlus II, MP-II GX, & Quattro-II 48/5000/70| | ||
- | More information about the cable can be found in [[battery_compatibility: | + | **" |
- | Without properly connecting this cable, the battery | + | The specification for these minimum |
- | It is important to ensure this connection and display of the battery on the [[venus-os: | + | ===== 3. CAN-Bus wiring between |
+ | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | Without properly connecting this cable, |
- | Using the latest firmware | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery | + | |
- | B-Box relays: | + | |
Line 195: | Line 208: | ||
=== 4.2 Charge parameters === | === 4.2 Charge parameters === | ||
- | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: | + | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: |
Line 203: | Line 216: | ||
+ | | Float voltage | ||
=== 4.3 Inverter Settings === | === 4.3 Inverter Settings === | ||
Line 237: | Line 254: | ||
- | ===== 5. Venus-device | + | ===== 5. GX device |
Line 245: | Line 262: | ||
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
Line 255: | Line 271: | ||
- | === Color Control GX Configuration === | + | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. |
- | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | + | |
- | === Venus GX Configuration | + | === GX Device with multiple CAN-bus port configuration |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | With GX devices that have two CAN-bus interfaces available |
- | This allows data from the MPPT and BYD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
+ | This allows data from the MPPT and BYD battery simultaneously. | ||
- | ===== 6. VE-Direct | + | === Color Control GX Configuration - Not Recommended |
+ | The CCGX only has one available VE.Can interface. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery BMS-Can CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can | ||
- | In normal operation the MPPT charge characteristics are governed by the [[venus-os: | + | For this reason it is recommended |
- | This section presumes familiarity with [[victronconnect: | + | ===== 6. Solar Charging ===== |
- | The settings below are a precautionary measure. | + | ==== 6.1 Victron MPPT charger settings ==== |
- | ^MPPT Parameter ^ Setting ^ | + | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os: |
+ | |Battery voltage | ||
+ | Therefore it is essential that there is also either a generator or DC MPPT charge controller for overall system stability. If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. | ||
Line 288: | Line 316: | ||
- | As a safety precaution, | + | When the grid is connected there are two software controls |
- | You can then start the inverter/ | + | If the grid fails and no AC supply is available, in this deeply discharged state, and the battery |
- | === Step 1. Check that the BYD battery is visible on the Venus-device list === | + | The GX device will remain on, as there is still DC voltage provided by the batteries for a while. |
+ | If instead the battery becomes completely discharged the battery will further protect itself by not just sending the 0A discharge limit, but also disconnecting DC voltage from the battery terminals (via internal MOSFETS). As there is no DC voltage available on the terminals any more the GX device will also shut down, and the inverter will also then be hard off (not just software off). | ||
+ | If you then reconnect a DC charge source, or AC input supply (grid or generator), after approximately 2 minutes the inverter will start up again, power the DC bus, powering up the GX device, and then powering up the battery, and the system will recover. | ||
+ | === Step 1. Check that the BYD battery is visible on the GX device list === | ||
Line 300: | Line 337: | ||
* BYD firmware version (see requirement above) | * BYD firmware version (see requirement above) | ||
* CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | ||
Line 307: | Line 344: | ||
=== Step 2. Check that the BYD battery is ready for use === | === Step 2. Check that the BYD battery is ready for use === | ||
When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | ||
Line 313: | Line 350: | ||
- | Also check that your are seeing the expected | + | Also check that your are seeing the expected |
Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | ||
Line 345: | Line 382: | ||
- | ===== 9. Step by Step Guide ===== | ||
- | If you need further details, a user contributed [[battery_compatibility: | + | ===== 9. Step by Step Installation Guide ===== |
- | ===== 10. Known Issues ===== | + | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// |
- | === 10.1 Inaccurate State of Charge (SoC) Readings === | + | [[https:// |
- | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | + | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, |
+ | ==== Introduction to the new BYD Premium range LVL and LVS ==== | ||
+ | ===== 10. Known Issues with B-Box Pro models ===== | ||
+ | === 10.1 Inaccurate State of Charge (SoC) Readings with B-Box Pro models === | ||
+ | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | ||
Line 361: | Line 419: | ||
This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | ||
- | The reported State of Charge will self correct when the battery is 100% full or near 10% empty, and this can appear as sudden jumps in the VRM from very little load or charge. | + | The reported State of Charge will self correct when it reaches |
This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | ||
Line 367: | Line 425: | ||
=== Work-arounds === | === Work-arounds === | ||
- | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: | + | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: |
The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | ||
Line 408: | Line 466: | ||
- | ===== 11. Further Information ===== | + | |
+ | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== | ||
+ | The Remote On/Off input of the two mentioned solar charger models is used to signal that they can or cannot charge the battery. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | ||
+ | B-Box relays: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
+ | ===== 13. Further Information ===== | ||
For information about where to buy or find suitably qualified installers, visit the [[https:// | For information about where to buy or find suitably qualified installers, visit the [[https:// | ||
Line 417: | Line 536: | ||
