battery_compatibility:byd_b-box [2019-01-22 10:16] – external edit 127.0.0.1 | battery_compatibility:byd_b-box [2019-02-18 14:08] – guy_stewart | ||
Line 144: | Line 144: | ||
Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | ||
- | Up to 5 L modules can be installed per L series BCU; 6 or more will require additional BCU. | + | Up to 4 L modules can be installed per L series BCU; 5 or more will require additional BCU. |
Line 256: | Line 256: | ||
This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the current limit is 35A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. | This parameters page is also a good place to check that all batteries are connected and working properly. In normal working conditions, for the 2.5 model, the current limit is 35A per cell. For example, 140A charge current limit ( 140 / 35 = 4 ) means there are 4 BYD battery cells connected. | ||
+ | Note this figure has been increased in recent firmware versions - so it may appear slightly higher (eg 40A per cell). | ||
Line 313: | Line 314: | ||
- | Also check that your are seeing the expected | + | Also check that your are seeing the expected |
Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | ||
Line 361: | Line 362: | ||
This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | ||
- | The reported State of Charge will self correct when the battery is 100% full or near 10% empty, and this can appear as sudden jumps in the VRM from very little load or charge. | + | The reported State of Charge will self correct when it reaches |
This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | ||
Line 407: | Line 408: | ||
+ | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
+ | If your system is supplied only with AC-bus solar charging, this may prevent the solar inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | ||
===== 11. Further Information ===== | ===== 11. Further Information ===== | ||
Line 417: | Line 426: | ||
