battery_compatibility:byd_b-box [2018-11-23 22:58] – guy_stewart | battery_compatibility:byd_b-box [2024-01-22 07:32] (current) – guy_stewart | ||
+ | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ Premium LVS 4.0 ^ LV Flex 5 ^ | ||
+ | | Appearance | {{ : | ||
+ | | ESS | yes| yes| yes| yes| yes| yes| | ||
+ | | Grid Backup| | ||
+ | | Off-Grid| | ||
+ | | Module capacity| | ||
+ | | Module limit | 32| 32| 12| 64| 64| 64| | ||
+ | | Max capacity| | ||
+ | ===== 1. Product & System compatibility | ||
- | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | + | === 1.1 Offgrid, Backup and Energy Storage Systems |
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron Venus-device and supports multiple battery modules. | + | |
- | ==== 1. Product & system compatibility ==== | + | |
- | === 1.1 Offgrid, Backup and Energy Storage Systems | + | |
Line 14: | Line 18: | ||
* Off-grid | * Off-grid | ||
+ | __Special note for Off-Grid systems__ | ||
- | === 1.2 A Venus-device is required, | + | === 1.2 A GX device is required, |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | |
- | When used with B-Box batteries, the minimum required firmware version for the [[https:// | + | |
- | === 1.3 All 48V Multis, MultiPlusses, | + | |
- | The minimum firmware version is 422. Though updating to the latest firmware is recommended where possible. | + | |
- | These inverter/ | + | |
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the Venus-device. | + | |
- | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the Venus-device. | + | |
+ | When used with B-Box Pro series batteries, the minimum supported firmware version for the [[venus-os: | ||
- | === 1.4 All 48V BlueSolar | + | === 1.3 All 48V Multis, MultiPlusses, |
- | For proper operation, the B-Box battery needs to be able to control | + | The minimum supported firmware version is 469. Updating |
- | It is recommended | + | |
- | __MPPTs with a VE.Direct port__ | + | These inverter/ |
- | MPPTs are controlled via the Venus-device. Make sure the Venus-device | + | In grid connected systems, advanced control functions |
- | The MPPT requires connection to the Venus-device to regulate charge currents as the batteries require | + | In off-grid systems, the control functions of the BYD Battery Management System |
- | To test operation, try disconnecting | + | |
- | __MPPTs with a VE.Can port__ | + | === 1.4 Solar Charger compatibility === |
- | Firmware should be at least version 2.05. | + | All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible (*). |
- | When using VE.Can | + | Some of our Solar Chargers feature a VE.Direct communication port, some feature a VE.Can |
+ | When planning to use the VE.Can communications port to connect the Solar Charger(s), make sure to select a GX Device that has sufficient CAN-Bus ports. The Color Control GX has only one such port, its VE.Can port, and is therefor not suitable. All other GX Devices can be used, since they have two ports. One can then be used to connect the BYD battery, and the other to connect the Solar Charger. | ||
Line 65: | Line 58: | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | On-screen, or via Remote Console on the Venus-device, this version is named v4.13. | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. |
- | Batteries with older firmware | + | BYD B-Box Premium batteries |
- | + | Victron is not compatible with the BYD HVS/HVM range of high-voltage batteries. | |
- | ==== 1.6 Minimum Battery Sizing ==== | + | ===== 2. Minimum Battery Sizing |
- | The following charge rates are managed automatically by the BYD BMU and Venus-device. Temperature effects on charge rates should be considered in the design stage in hot and cold climates. | + | The following charge rates are managed automatically by the BYD BMU and [[venus-os: |
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | ||
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | ||
- | | Appearance | {{ : | ||
- | | ESS Self Consumption| | ||
- | | Grid Backup| | ||
- | | Off-Grid| | ||
- | | Capacity per module| | ||
- | | Maximum quantity of modules| | ||
- | | Maximum energy capacity| | ||
Line 100: | Line 85: | ||
|Phases| | |Phases| | ||
- | | Quattro 48/ | + | | Quattro |
Line 118: | Line 103: | ||
Line 131: | Line 117: | ||
Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | ||
- | Up to 5 L modules can be installed per L series BCU; 6 or more will require additional BCU. | + | Up to 4 L modules can be installed per L series BCU; 5 or more will require additional BCU. |
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/ | ||
+ | | MultiPlus, MultiPlus II, MP-II GX, & Quattro-II 48/ | ||
+ | | Quattro 48/ | ||
+ | | Quattro & MultiPlus-II 48/ | ||
+ | | EasySolar 48/ | ||
+ | |Phases| | ||
- | ==== 2. Wiring of CAN-bus cable between B-Box and Venus-device ==== | + | === Battery Modules Required - Premium LV Flex 5.0 === |
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the Venus-device. | + | |Phases| |
+ | | Inverter/Charger | On-Grid | On-Grid | Off-grid | Off-grid | | ||
+ | | MultiPlus 48/500 & 48/ | ||
+ | | MultiPlus 48/1200 & 48/ | ||
+ | | MultiPlus 48/ | ||
+ | | MultiPlus & MultiPlus II & MP-II GX 48/3000/35| 1| 3| 2| 4| | ||
- | More information about the cable can be found in [[battery_compatibility: | + | **" |
- | Without properly connecting this cable, the battery | + | The specification for these minimum |
- | It is important to ensure this connection and display of the battery on the Venus-device display before attempting firmware updates or settings changes on other devices if they depend on the power supply from the battery. Without this connection, the battery may turn off unexpectedly. If a reliable DC power supply is required, you can temporarily disconnect the individual BYD battery cells inside their cabinet from the internal Battery Management Unit (BMU). It is the BMU that signals the battery cells to shut down if the signal from the Venus-device has not been received. This is a temporary measure, DO NOT attempt to operate | + | ===== 3. CAN-Bus wiring between |
+ | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | ==== 3. Wiring | + | Without properly connecting this cable, the battery will not show up on the display |
- | Using the latest | + | It is important to ensure this connection and display of the battery on the [[venus-os: |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | + | ===== 4. VEConfigure settings |
- | B-Box relays: | + | |
- | ==== 4. VEConfigure settings ==== | + | |
This section presumes familiarity with [[https:// | This section presumes familiarity with [[https:// | ||
Line 191: | Line 208: | ||
=== 4.2 Charge parameters === | === 4.2 Charge parameters === | ||
- | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the Venus-device to the inverter/ | + | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: |
+ | === Charger tab === | ||
^ VEConfigure Charge Parameter | ^ VEConfigure Charge Parameter | ||
Line 197: | Line 216: | ||
+ | | Float voltage | ||
+ | === 4.3 Inverter Settings === | ||
+ | In the Inverter tab of VEConfigure | ||
+ | ^VEConfigure Inverter Parameter | ||
+ | |DC input low shut-down | 47V| | ||
+ | |DC input low restart | ||
+ | |DC input low pre-alarm* | 51V| | ||
+ | * The pre-alarm setting is dependant on your preference and on site specific requirements. You may wish for this to be activated earlier (eg 53V) in an off grid situation to allow time to start a backup generator. If the system is configured in ESS mode, you may not wish to have this alarm trigger until below the Sustain threshold voltage (eg 49V), as this system is in no danger normally and will ' | ||
+ | === ESS System Settings === | ||
+ | If you are using the battery as part of a [[ess: | ||
- | === Option A: ESS Assistant | + | The settings that are specific to the BYD battery in the VEConfigure |
- | Use this option for ESS systems. | + | |
- | Select the fifth battery | + | Select the externally managed Lithium |
^ ESS Parameter ^ Settings ^ | ^ ESS Parameter ^ Settings ^ | ||
|Sustain voltage. | |Sustain voltage. | ||
|Dynamic cut-off values | set all values to 47V.| | |Dynamic cut-off values | set all values to 47V.| | ||
- | |Restart offset: | + | |Restart offset: |
- | === Option B: Off-grid system using CAN-bus cable. ==== | ||
- | You will need the latest firmware on all connected devices. | ||
- | On the Venus-device, go to Settings, System setup: | + | |
+ | ===== 5. GX device configuration ===== | ||
+ | On the [[venus-os: | ||
Line 225: | Line 263: | ||
- | In the Inverter tab of VEConfigure | + | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the GX device. Menu path: //Settings -> Services -> CAN-profile// |
- | ^VEConfigure Inverter Parameter | + | |
- | |DC input low shut-down | 47V| | + | |
- | |DC input low restart | + | |
- | |DC input low pre-alarm* | 51V| | + | |
- | * The pre-alarm setting is dependant on your preference and on site specific requirements. You may wish for this to be activated earlier (eg 53V) in an off grid situation to allow time to start a backup generator. If the system is configured in ESS mode, you may not wish to have this alarm trigger until below the Sustain threshold voltage (eg 49V), as this system is in no danger normally and will ' | + | |
- | ==== 5. Venus-device Configuration ==== | + | |
- | If you have a VE.Can MPPT, it is advised to use the Venus GX in place of the CCGX. | + | |
- | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | |
Line 245: | Line 271: | ||
- | === Color Control GX Configuration === | + | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. |
+ | === GX Device with multiple CAN-bus port configuration === | ||
+ | With GX devices that have two CAN-bus interfaces available (eg Cerbo GX and Venus GX), the VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND), or BMS-Can ports. | ||
+ | This allows data from the MPPT and BYD battery simultaneously. | ||
+ | The CAN-bus connections are galvanically isolated at the BYD BMU. There is no issues using the non-isolated connection of the VGX. | ||
+ | === Color Control GX Configuration | ||
- | The CCGX only has one available VE.Can | + | The CCGX only has one available VE.Can |
- | === Venus GX Configuration === | + | For this reason it is recommended to use the Cerbo GX instead. |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | ===== 6. Solar Charging ===== |
- | This allows data from the MPPT and BYD battery simultaneously. You will still need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
- | Be aware that this additional CAN-bus interface is not electrically isolated. | + | ==== 6.1 Victron MPPT charger settings ==== |
- | ===== 6. Configure VE-Direct | + | Victron |
- | In normal operation the MPPT charge characteristics are governed by the Venus-device connected to the BYD battery. | + | ^ MPPT Parameter ^ Setting ^ |
+ | |Battery voltage | ||
+ | |Absorption voltage | ||
- | This section presumes familiarity with [[victronconnect: | + | Use [[victronconnect: |
- | The settings below are a precautionary measure. | + | ==== 6.2 Self-Startup from Low voltage shutdown modes ==== |
- | ^MPPT Parameter ^ Setting ^ | + | In a correctly configured system, the inverter will shut itself down before the batteries enter a self protective shut down state. |
- | |Absorption voltage | + | Therefore it is essential that there is also either a generator or DC MPPT charge controller for overall system stability. If your system is charged only with an AC-coupled PV inverter, this may prevent the AC-coupled PV inverter from starting up to recharge the batteries. |
Line 278: | Line 316: | ||
- | As a safety precaution, | + | When the grid is connected there are two software controls |
- | You can then start the inverter/ | + | If the grid fails and no AC supply is available, in this deeply discharged state, and the battery |
- | === Step 1. Check that the BYD battery is visible on the Venus-device list === | + | The GX device will remain on, as there is still DC voltage provided by the batteries for a while. |
+ | If instead the battery becomes completely discharged the battery will further protect itself by not just sending the 0A discharge limit, but also disconnecting DC voltage from the battery terminals (via internal MOSFETS). As there is no DC voltage available on the terminals any more the GX device will also shut down, and the inverter will also then be hard off (not just software off). | ||
+ | If you then reconnect a DC charge source, or AC input supply (grid or generator), after approximately 2 minutes the inverter will start up again, power the DC bus, powering up the GX device, and then powering up the battery, and the system will recover. | ||
+ | === Step 1. Check that the BYD battery is visible on the GX device list === | ||
Line 290: | Line 337: | ||
- | * Venus-device firmware version (update to latest version, v2.15 or later) | + | * [[venus-os: |
* BYD firmware version (see requirement above) | * BYD firmware version (see requirement above) | ||
* CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | ||
Line 297: | Line 344: | ||
=== Step 2. Check that the BYD battery is ready for use === | === Step 2. Check that the BYD battery is ready for use === | ||
When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | ||
+ | Also check that your are seeing the expected 35-40 A of discharge current per installed module. | ||
Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | ||
Line 334: | Line 383: | ||
- | ===== 9. Step by Step Guide ===== | + | ===== 9. Step by Step Installation |
- | If you need further details, | + | There is a step by step installation |
- | ===== 10. Known Issues ===== | + | [[https:// |
- | ==== 10.1 Inaccurate State of Charge (SoC) Readings ==== | + | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, |
- | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the Venus-device and reported to the user and the system. | + | ==== Introduction to the new BYD Premium range LVL and LVS ==== |
+ | ===== 10. Known Issues with B-Box Pro models ===== | ||
+ | === 10.1 Inaccurate State of Charge (SoC) Readings with B-Box Pro models === | ||
+ | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | ||
Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | ||
Line 350: | Line 419: | ||
This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | ||
- | The reported State of Charge will self correct when the battery is 100% full or near 10% empty, and this can appear as sudden jumps in the VRM from very little load or charge. | + | The reported State of Charge will self correct when it reaches |
This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | ||
Line 356: | Line 425: | ||
=== Work-arounds === | === Work-arounds === | ||
- | If precise state of charge is important, | + | If precise state of charge is important, it is possible |
The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | ||
Line 371: | Line 440: | ||
- | ==== 10.2 125A cabinet limit ==== | + | === 10.2 125A cabinet limit === |
The IP55 BYD cabinets are designed to take 4 battery modules and are supplied with 125A circuit breakers. Each battery module is able to supply and receive a continuous 35A, all together a combined 140A. This means it is possible to overload the circuit breaker. | The IP55 BYD cabinets are designed to take 4 battery modules and are supplied with 125A circuit breakers. Each battery module is able to supply and receive a continuous 35A, all together a combined 140A. This means it is possible to overload the circuit breaker. | ||
Line 382: | Line 451: | ||
- | ==== 10.3 Cold Weather Performance | + | === 10.3 Cold Weather Performance === |
The BYD cells will limit the charge current allowed at lower temperatures. | The BYD cells will limit the charge current allowed at lower temperatures. | ||
Line 395: | Line 464: | ||
Cells will also heat themselves up when charged and discharged. | Cells will also heat themselves up when charged and discharged. | ||
- | There has been a firmware revision for the BYD battery modules and BMU that improves cold weather performance slightly. This manual will be updated with the new (slightly improved) specifications when stock supplied with the new firmware has had sufficient time to enter the market. | + | There has been a firmware revision for the BYD battery modules and BMU that improves cold weather performance slightly. This manual will be updated with the new (slightly improved) specifications when stock supplied with the new firmware has had sufficient time to enter the market. |
+ | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== | ||
+ | The Remote On/Off input of the two mentioned solar charger models is used to signal that they can or cannot charge the battery. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | ||
+ | B-Box relays: | ||
+ | The 'high voltage' | ||
+ | 1: If you have 2 or more batteries in your system, you can try shutting down the system once it is as close to fully charged as possible, and then physically connecting the batteries in smaller groups (or even individually) so that balancing can occur on each individual battery without it being masked by the others connected in parallel. It may help you to see the indicator lights on the battery (if available on that model) to find which battery might be out of balance with the others. You can also monitor this in VRM and the GX device using the min/max cell voltage reporting. | ||
+ | 2: Contact your BYD dealer for further assistance (they can provide additional software to see even more detailed individual cell level data), or assist with other potential solutions. | ||
+ | ===== 13. Further Information ===== | ||
+ | For information about where to buy or find suitably qualified installers, visit the [[https:// | ||
+ | Further community discussion about installing and using BYD and Victron can found at [[https:// | ||
- | ===== 11. DISQUS ===== | + | ===== DISQUS ===== |
~~DISQUS~~ | ~~DISQUS~~ |
