battery_compatibility:bsl
battery_compatibility:bsl [2021-04-16 12:29] – bslbatt | battery_compatibility:bsl [2022-01-14 10:08] – [Configuration settings] dylanc | ||
====== Victron & BSLBATT Lithium batteries ====== | ====== Victron & BSLBATT Lithium batteries ====== | ||
- | Introduction | + | [[https:// |
- | WISDOM INDUSTRIAL POWER Co.,LTD ([[https:// | + | |
===== Product & System compatibility ===== | ===== Product & System compatibility ===== | ||
Line 10: | Line 8: | ||
=== Offgrid, Backup and Energy Storage Systems (ESS) === | === Offgrid, Backup and Energy Storage Systems (ESS) === | ||
Victron + BSLBATT can be used for the following system types: | Victron + BSLBATT can be used for the following system types: | ||
Line 58: | Line 57: | ||
Integration instructions for Victron and BSLBATT is described in this manual - | Integration instructions for Victron and BSLBATT is described in this manual - | ||
+ | Specific manuals for various models of battery: | ||
+ | * 5.1kWh battery- {{ : | ||
+ | * 6.4kWh battery- {{ : | ||
+ | * 8.2kWh battery- {{ : | ||
+ | * 10.2kWh battery- {{ : | ||
Here is a series of screenshots showing the result: | Here is a series of screenshots showing the result: | ||
Line 67: | Line 73: | ||
battery_compatibility/bsl.txt · Last modified: 2024-02-21 14:22 by warwickchapman
