battery_compatibility:bluenova
battery_compatibility:bluenova [2020-06-22 10:46] – [5. Color Control GX Configuration] rickerts_bluenova.co.za | battery_compatibility:bluenova [2020-08-27 17:21] – [7. Recommended & Maximum Charge / Discharge Values] rickerts_bluenova.co.za | ||
Line 173: | Line 173: | ||
+ | ==== 7. Recommended Maximum Charge / Discharge Values ==== | ||
- | ==== 7. Configure MPPT ==== | + | ==== 8. Configure MPPT ==== |
- Disable Autodetect voltage | - Disable Autodetect voltage | ||
- Set Battery voltage to 48V. | - Set Battery voltage to 48V. |
battery_compatibility/bluenova.txt · Last modified: 2022-04-07 10:40 by dirkbluenova
