battery_compatibility:bluenova
battery_compatibility:bluenova [2019-08-26 15:07] – [2. BlueNova product range] dirkbluenova | battery_compatibility:bluenova [2022-04-07 10:40] (current) – dirkbluenova | ||
- | Victron Energy and BlueNova Energy LiFePo4 Batteries | + | |
The BlueNova Energy (www.bluenova.co.za) range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | The BlueNova Energy (www.bluenova.co.za) range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | ||
- | 1.1Product | + | === 1.1 Product |
- | Victron + BlueNova can be used for the following systems | + | Victron + BlueNova |
1.Off Grid | 1.Off Grid | ||
2.Backup | 2.Backup | ||
3.Energy Storage | 3.Energy Storage | ||
- | 1.2Colour Control | + | === 1.2 GX device |
- | When used with BlueNova Batteries the minimum | + | When used with BlueNova |
- | 1.3All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids | + | === 1.3 All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids, Quattros |
- | When the BlueNova battery is installed in a Victron ESS installation, | + | When the BlueNova |
- | 2.BlueNova Energy product range | + | ==== 2.BlueNova Energy product range ==== |
- | The BlueNova range is supplied with a BMS as standard on all current | + | The BlueNova |
- | ==== 3. Wiring of Can.Bus cable between BlueNova and CCGX. ==== | + | ==== 3. Wiring of Can.Bus cable between BlueNova |
+ | No RJ45 cable is supplied for this connection . | ||
+ | Plug the GX device side of the cable into one of the VE.Can sockets on the back of the GX device or "BMS Can" | ||
+ | For BlueNova | ||
+ | Without properly connecting this cable, the battery will stop charging/ | ||
+ | To view more information on the RacPower | ||
Line 39: | Line 51: | ||
- | An RJ45 cable is supplied with each BlueNova battery. | ||
- | Plug the CCGX side of that cable into one of the VE.Can sockets on the back of the CCGX. Plug the other end into the battery. Then, plug a VE.Can terminator in the other VE.Can socket on the CCGX. Two VE.Can terminators are included with the package of the CCGX as an accessory – only one is used. Keep the other one as a spare. | ||
- | Without properly connecting this cable, the battery will stop charging/ | ||
Line 49: | Line 57: | ||
=== 4.1 Charge parameters === | === 4.1 Charge parameters === | ||
Line 60: | Line 73: | ||
=== 4.2 ESS Assistant === | === 4.2 ESS Assistant === | ||
- | Select the fourth | + | Select the fifth battery type: |
Line 68: | Line 81: | ||
- | ==== 5. Color Control | + | ==== 5. GX device |
- | Select the //VE.Can & CAN-bus BMS (250 kbaud)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | In most cases nothing needs changing: new Blue Nova Energy batteries come with 500kbps |
+ | In case a setting does need changing, such as setting a different baud rate or configuring a VE.Can port to be used for BMS-Can instead, use the menu path //Settings -> Services -> CAN-profile// | ||
+ | Note that it is not possible | ||
+ | All BlueNova Energy products can work with either 250kbps or 500kbps. On the older batteries this mean installing new firmware and on the new batteries this is selectable on the user interface on the battery. The default baud rate on newly delivered BlueNova Energy batteries 500kbps. | ||
Line 79: | Line 98: | ||
- | After properly wiring and setting up, the BlueNova will be visible as a battery in the device list: | + | After properly wiring and setting up, the BlueNova |
Line 108: | Line 127: | ||
If you have multiple batteries, a single entry will show up, which represents all batteries. | If you have multiple batteries, a single entry will show up, which represents all batteries. | ||
The parameters option within the battery page shows the actual battery charge and discharge limits. | The parameters option within the battery page shows the actual battery charge and discharge limits. | ||
+ | To be able to monitor all individual paralleled BlueNova Energy batteries in an installation, | ||
+ | (The BlueNova Energy BMAC Online unit can be purchased seperately from your BlueNova Energy registered installer or dealer.) | ||
- | ==== 6. Configure MPPT ==== | + | |
+ | ==== 6. BlueNova Energy battery setup with DVCC enabled ==== | ||
+ | (DVCC - Distributed Voltage and Current Control) | ||
+ | Introduction and features | ||
+ | With the latest Victron Energy GX device firmware installed, | ||
+ | Activating the DVCC in this way, changes the GX device from a passive monitor into an active controller. | ||
+ | The GX device | ||
+ | {{https:// | ||
+ | {{https:// | ||
+ | Shared Voltage Sense (SVS) | ||
+ | Works with VE.Bus devices and VE.Direct Solar Chargers. | ||
+ | The system automatically selects the best available voltage measurement. It will use the voltage from the BlueNova Energy | ||
+ | The voltage displayed on the GUI reflects the same voltage measurement. | ||
+ | **Shared Voltage Sense** (SVS) is by default enabled when DVCC is enabled. It can be disabled with a switch in the Settings → System Setup menu. | ||
+ | **Limit charge current** | ||
+ | This is a user-configurable maximum charge current setting and can, in majority of cases, be | ||
+ | To enable or disable DVCC, see Settings → System Setup in the menus. | ||
+ | **DVCC Requirements :** | ||
+ | Battery compatilibity | ||
+ | DVCC has extensively been tested on BlueNova Energy batteries and is therefore fully supported . | ||
+ | **Firmware versions :** | ||
+ | Do not use DVCC in cases where these requirements(Victron) are not met. In all cases we recommend to install the latest available firmware during commissioning. Once running well, there is no need to pro- actively update firmware without reason. In case of difficulty, the first action is to update firmware. | ||
+ | **Required minimum firmware versions:** | ||
+ | BlueNova Energy | ||
+ | BlueNova Energy BMMC : V3.5 + | ||
+ | Multi/ | ||
+ | MultiGrid: 424 | ||
+ | GX device: v2.12 VE.Direct MPPTs: v1.29 | ||
+ | VE.Can MPPT Solar Chargers cannot be used: they do not yet support the new control mechanisms. | ||
+ | (Latest VeCan /VeDirect MPPT Solar Chargers is compatible...) | ||
+ | Lynx Ion + Shunt: v2.04 Lynx BMS: v1.09 | ||
+ | In case of an ESS System, the ESS Assistant needs to be version 164 or later (Released in November 2017). | ||
+ | ==== 7. Recommended Maximum Charge / Discharge Values ==== | ||
+ | ==== 8. Configure MPPT ==== | ||
- Disable Autodetect voltage | - Disable Autodetect voltage | ||
- Set Battery voltage to 48V. | - Set Battery voltage to 48V. | ||
Line 116: | Line 210: | ||
It is recommended to make these settings using the VictronConnect App and Bluetooth. | It is recommended to make these settings using the VictronConnect App and Bluetooth. | ||
+ | ** - All latest GX devices applicable. | ||
- | ~~DISQUS~~ | ||
battery_compatibility/bluenova.txt · Last modified: 2022-04-07 10:40 by dirkbluenova
