battery_compatibility:bluenova
battery_compatibility:bluenova [2019-08-26 15:07] – [2. BlueNova product range] dirkbluenova | battery_compatibility:bluenova [2019-08-27 08:12] – guy_stewart | ||
- | Victron Energy and BlueNova Energy LiFePo4 Batteries | + | |
The BlueNova Energy (www.bluenova.co.za) range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | The BlueNova Energy (www.bluenova.co.za) range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | ||
- | 1.1Product | + | === 1.1 Product |
Victron + BlueNova can be used for the following systems | Victron + BlueNova can be used for the following systems | ||
Line 12: | Line 11: | ||
3.Energy Storage | 3.Energy Storage | ||
- | 1.2Colour | + | === 1.2 Colour |
When used with BlueNova Batteries the minimum firmware version for the Colour Control / Venus G X is v2.02. It is recommended to always use the latest Firmware version for the Colour Control/ | When used with BlueNova Batteries the minimum firmware version for the Colour Control / Venus G X is v2.02. It is recommended to always use the latest Firmware version for the Colour Control/ | ||
- | 1.3All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids and Quattros are compatible | + | === 1.3 All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids and Quattros are compatible |
When the BlueNova battery is installed in a Victron ESS installation, | When the BlueNova battery is installed in a Victron ESS installation, | ||
Line 22: | Line 21: | ||
- | 2.BlueNova Energy product range | + | ==== 2.BlueNova Energy product range ==== |
The BlueNova range is supplied with a BMS as standard on all current | The BlueNova range is supplied with a BMS as standard on all current | ||
Line 28: | Line 27: | ||
==== 3. Wiring of Can.Bus cable between BlueNova and CCGX. ==== | ==== 3. Wiring of Can.Bus cable between BlueNova and CCGX. ==== | ||
- | {{: | + | {{https:// |
+ | No RJ45 cable is supplied for this connection . | ||
+ | Plug the CCGX/ | ||
+ | Without properly connecting this cable, the battery will stop charging/ | ||
Line 39: | Line 41: | ||
- | An RJ45 cable is supplied with each BlueNova battery. | ||
- | Plug the CCGX side of that cable into one of the VE.Can sockets on the back of the CCGX. Plug the other end into the battery. Then, plug a VE.Can terminator in the other VE.Can socket on the CCGX. Two VE.Can terminators are included with the package of the CCGX as an accessory – only one is used. Keep the other one as a spare. | ||
- | Without properly connecting this cable, the battery will stop charging/ | ||
Line 49: | Line 47: | ||
=== 4.1 Charge parameters === | === 4.1 Charge parameters === | ||
Line 116: | Line 114: | ||
It is recommended to make these settings using the VictronConnect App and Bluetooth. | It is recommended to make these settings using the VictronConnect App and Bluetooth. | ||
+ | ** - All latest GX devices applicable. | ||
battery_compatibility/bluenova.txt · Last modified: 2022-04-07 10:40 by dirkbluenova
