battery_compatibility:bluenova
battery_compatibility:bluenova [2017-06-14 10:47] – andrevesa | battery_compatibility:bluenova [2022-04-07 08:42] – dirkbluenova | ||
+ | ====== Victron Energy and BlueNova Energy LiFePo4 Batteries ====== | ||
- | ====== Victron Energy and BlueNova | + | The BlueNova |
- | The BlueNova (www.bluenova.co.za) range of Lithium Iron Phosphate batteries is compatible with Victron products in various systems. | + | === 1.1 Product and System Compatibility === |
- | 1.1 Product and System Compatibility | + | Victron + BlueNova Energy can be used for the following systems |
- | Victron + BlueNova can be used for the following systems | + | 1.Off |
- | - Off Grid | + | |
- | - Backup | + | |
- | - Energy Storage | + | |
- | 1.2 Colour Control GX is required | + | 2.Backup |
- | When used with BlueNova Batteries the minimum firmware version for the Colour Control is v2.02. It is recommended to always use the latest Firmware version for the Colour Control. | + | 3.Energy Storage |
- | 1.3 All 48V Multi’s, MultiPlus, Multigrids and Quattros are compatible | + | === 1.2 GX device is required === |
- | When the BlueNova | + | When used with BlueNova |
- | For other systems, such as off-grid systems and backup systems, | + | |
- | For more Victron-related settings see the VEConfigure section below | + | |
- | 1.4 48V BlueSolar MPPT Chargers | + | === 1.3 All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids, Quattros and EasySolars |
- | The Orion BMS BlueNova | + | When the BlueNova |
- | MPPTs with a VE.Direct port. These are controlled via the Color Control GX. Make sure the CCGX runs v2.02 or later, and also update the MPPTs to the latest available version. | + | |
- | To test operation, try disconnecting the CCGX from the MPPT. After a time-out, the MPPT will stop charging | + | |
- | 2. BlueNova product range | ||
- | The BlueNova range can be supplied with 2 different BMS. | ||
- | - Models with a 123 BMS | ||
- | - Models with an Orion BMS | ||
- | Please contact BlueNova for more information | ||
- | 3. | + | ==== 2.BlueNova |
- | {{: | + | The BlueNova Energy range is supplied with a BMS as standard on all current |
+ | ==== 3. Wiring of Can.Bus cable between BlueNova Energy and GX device. ==== | ||
+ | No RJ45 cable is supplied for this connection . | ||
+ | Plug the GX device side of the cable into one of the VE.Can sockets on the back of the GX device or "BMS Can" | ||
+ | For BlueNova | ||
+ | Without properly connecting this cable, the battery will stop charging/ | ||
+ | To view more information on the RacPower | ||
- | An RJ45 cable is supplied with each Bluenova battery. | ||
- | Plug the CCGX side of that cable into one of the VE.Can sockets on the back of the CCGX. Plug the other end into the battery. Then, plug a VE.Can terminator in the other VE.Can socket on the CCGX. Two VE.Can terminators are included with the package of the CCGX as an accessory – only one is used. Keep the other one as a spare. | ||
- | Without properly connecting this cable, the battery will stop charging/ | ||
- | 4. VEConfigure settings | ||
- | 4.1 | ||
Line 64: | Line 53: | ||
+ | ==== 4. VEConfigure settings ==== | ||
+ | === 4.1 Charge parameters === | ||
- | 4.2 ESS Assistant | ||
- | Select the fourth | + | |
+ | === 4.2 ESS Assistant === | ||
+ | Select the fifth battery type: | ||
Line 77: | Line 81: | ||
- | 5. Color Control | + | ==== 5. GX device |
- | Enable the CAN-bus BMS Service in th}}e CCGX. Menu path: Settings → Services → CAN-bus BMS. Note that this changes | + | |
+ | In most cases nothing needs changing: new Blue Nova Energy batteries come with 500kbps | ||
+ | In case a setting does need changing, such as setting a different baud rate or configuring | ||
+ | Note that it is not possible | ||
+ | All BlueNova Energy products can work with either 250kbps or 500kbps. On the older batteries this mean installing new firmware and on the new batteries this is selectable on the user interface on the battery. The default baud rate on newly delivered BlueNova Energy batteries 500kbps. | ||
- | After properly wiring and setting up, the Bluenova | + | After properly wiring and setting up, the BlueNova Energy |
Line 113: | Line 125: | ||
- | If you have multiple batteries, a single entry will show up, which represents all batteries | + | If you have multiple batteries, a single entry will show up, which represents all batteries. |
- | The parameters option within the battery page shows the actual battery charge and discharge limits | + | The parameters option within the battery page shows the actual battery charge and discharge limits. |
+ | To be able to monitor all individual paralleled BlueNova Energy batteries in an installation, | ||
+ | (The BlueNova Energy BMAC Online unit can be purchased seperately from your BlueNova Energy registered installer or dealer.) | ||
- | 6. Configure MPPT | + | |
+ | ==== 6. BlueNova Energy battery setup with DVCC enabled ==== | ||
+ | (DVCC - Distributed Voltage and Current Control) | ||
+ | Introduction and features | ||
+ | With the latest Victron Energy GX device firmware installed, | ||
+ | Activating the DVCC in this way, changes the GX device from a passive monitor into an active controller. | ||
+ | The GX device | ||
+ | {{https:// | ||
+ | {{https:// | ||
+ | Shared Voltage Sense (SVS) | ||
+ | Works with VE.Bus devices and VE.Direct Solar Chargers. | ||
+ | The system automatically selects the best available voltage measurement. It will use the voltage from the BlueNova Energy | ||
+ | The voltage displayed on the GUI reflects the same voltage measurement. | ||
+ | **Shared Voltage Sense** (SVS) is by default enabled when DVCC is enabled. It can be disabled with a switch in the Settings → System Setup menu. | ||
+ | **Limit charge current** | ||
+ | This is a user-configurable maximum charge current setting and can, in majority of cases, be | ||
+ | To enable or disable DVCC, see Settings → System Setup in the menus. | ||
+ | **DVCC Requirements :** | ||
+ | Battery compatilibity | ||
+ | DVCC has extensively been tested on BlueNova Energy batteries and is therefore fully supported . | ||
+ | **Firmware versions :** | ||
+ | Do not use DVCC in cases where these requirements(Victron) are not met. In all cases we recommend to install the latest available firmware during commissioning. Once running well, there is no need to pro- actively update firmware without reason. In case of difficulty, the first action is to update firmware. | ||
+ | **Required minimum firmware versions:** | ||
+ | BlueNova Energy | ||
+ | BlueNova Energy BMMC : V3.5 + | ||
+ | Multi/ | ||
+ | MultiGrid: 424 | ||
+ | GX device: v2.12 VE.Direct MPPTs: v1.29 | ||
+ | VE.Can MPPT Solar Chargers cannot be used: they do not yet support the new control mechanisms. | ||
+ | (Latest VeCan /VeDirect MPPT Solar Chargers is compatible...) | ||
+ | Lynx Ion + Shunt: v2.04 Lynx BMS: v1.09 | ||
+ | In case of an ESS System, the ESS Assistant needs to be version 164 or later (Released in November 2017). | ||
+ | ==== 7. Recommended Maximum Charge / Discharge Values ==== | ||
+ | ==== 8. Configure MPPT ==== | ||
- Disable Autodetect voltage | - Disable Autodetect voltage | ||
- Set Battery voltage to 48V. | - Set Battery voltage to 48V. | ||
- | It is recommended to make these settings using the VictronConnect App and Bluetooth | + | It is recommended to make these settings using the VictronConnect App and Bluetooth. |
+ | ** - All latest GX devices applicable. | ||
battery_compatibility/bluenova.txt · Last modified: 2022-04-07 10:40 by dirkbluenova
