auto-generator-start-stop:start [2015-08-20 12:57] – Page moved from auto-genset-start-stop:start to auto-generator-start-stop:start mvader | auto-generator-start-stop:start [2021-02-25 13:46] (current) – marmour | ||
- | ====== Automatic genset start/stop ====== | + | This page has been moved to manual |
- | There are many ways to automatically start and stop a genset using Victron equipment: | + | |
- | - potential free relay in a BMV-700. Start the generator on low battery voltage and/or low battery state of charge. See the [[http:// | + | |
- | - potential free relay in our Inverters, Multis and Quattros, using the Virtual switch | + | |
- | - potential free relay(s) in our Inverters, Multis and Quattros, using the [[assistants: | + | |
- | - (Expected in October 2015) [[ccgx: | + | |
- | It is also possible to combine above mentioned methods, by wiring the open contacts in parallel to each other. | + | |
- | ===== Starting a genset with three-wire interface ===== | + | |
- | To start such a genset, our the open/close contact needs to be converted into a start and stop pulse. Note that this solution should only be used on generators that do have a control panel monitoring and automatically stopping on loss of oil pressure and other sensors. In other words: do not wire this directly to the starter motor and fuel solenoid. | + | |
- | [add image with block diagram ] | + | |
- | [ add image with wiring diagram] | + | |
auto-generator-start-stop/start.1440068235.txt.gz · Last modified: by mvader
