assistants:three_phase_pv_inverter_assistant
assistants:three_phase_pv_inverter_assistant [2014-08-03 23:18] – mvader | assistants:three_phase_pv_inverter_assistant [2019-01-21 10:37] – [Step by step instructions] ictbeheer | ||
- | ====== | + | ====== PV Inverter Assistant |
Notes | Notes | ||
- | * For systems that have the new microprocessor (7 digit firmware numbers starts with 26 or 27 instead of 19 or 20), use the Self-consumption Hub-2 v3 Assistant instead. It is easier to configure the prioritization of solar power and offers more features. | ||
* This page shows VE.Bus System Configurator. Note that it is also possible to use VE,Bus Quick Configure. | * This page shows VE.Bus System Configurator. Note that it is also possible to use VE,Bus Quick Configure. | ||
+ | * The channels configuration, | ||
===== Step by step instructions ===== | ===== Step by step instructions ===== | ||
- | Select Phase 1 and right click to access VE Configure | + | Select Phase 1 and right click on the Multi icon to access VE Configure: |
Line 46: | Line 46: | ||
- | ~~DISQUS~~ | + | |
assistants/three_phase_pv_inverter_assistant.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
