assistants:three_phase_pv_inverter_assistant
assistants:three_phase_pv_inverter_assistant [2014-07-25 23:51] – Page moved and renamed from three_phase_grid_converter_assistant:three to assistants:three_phase_pv_inverter_assistant mvader | assistants:three_phase_pv_inverter_assistant [2019-01-21 10:37] – [Step by step instructions] ictbeheer | ||
- | Here follows the only way to configure | + | ====== PV Inverter Assistant in a three phase installation on 2xx ====== |
- | The Ideal Program | + | Notes |
+ | * This page shows VE.Bus System Configurator. Note that it is also possible to use VE,Bus Quick Configure. | ||
+ | * The channels configuration, | ||
- | Select Phase 1 and right click to access VE Configure | + | ===== Step by step instructions ===== |
+ | Select Phase 1 and right click on the Multi icon to access VE Configure: | ||
assistants/three_phase_pv_inverter_assistant.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
