assistants:self_consumption_hub-1
assistants:self_consumption_hub-1 [2016-01-08 16:39] ictbeheerassistants:self_consumption_hub-1 [2019-01-22 10:16] (current) – external edit 127.0.0.1
Line 7: Line 7:
 ===== When to use the hub-1 Assistant? ===== ===== When to use the hub-1 Assistant? =====
-Use the Assistant for these systems with Solar chargers, iedc-coupled solar power: +Use the Assistant for these systems with Solar chargers, where you want to disconnect from mains when possible. Which is the third policy on the list.
-  * Grid that allows feed-back +
-  * Grid that does not allow feed-back +
-  * Grid + a backup generator+
 +Usage of all other policies of Hub-1 have been deprecated, in favor of [[ess:start|ESS]].
-Do not use this Assistant for the following systemseven though they have solar chargers: +Besides below informationthere is more information about Hub-1 here
-  * No grid nor generator; solar only +  * [[https://www.victronenergy.com/blog/2016/06/10/color-control-gx-v1-51-released/|blog post about using a CCGX as a communication hub between a Multi (or Quattro) and one or more VE.Direct chargers]]
-  * Only a generator connected to the ac-input of the Multi or Quattro, no grid. +  * [[assistants:hub1_and_hub2_notes|]]
-More information+
-  * [[https://www.victronenergy.com/blog/2014/03/07/hub-1-available/|blog post on hub-1]]. +
-  * [[assistants:self_consumption_hub-1_policy-5]]+
 ===== Frequently asked questions ===== ===== Frequently asked questions =====
-=== Do I need to connect the Multi or Quattro to the MPPT with VE.Can? ===+=== Do I need to use the VE.Bus to VE.Can interface cable? ===
-No it is not requiredjust much recommendedAnd make sure to only use it when grid-feedback is enabeldThe advantages of using the VE.Bus to VE.Can interface are:+No, not anymore since CCGX v1.73See [[https://www.victronenergy.com/blog/2016/11/07/ccgx-v1-73-hub-1-byd-b-box-and-more-lithium-batteries/|v1.73 blogpost]] for details.
-  * The MPPT will automatically use the settings from the Multi, no need to configure the MPPT.
-  * Equalize is managed by the Multi
-  * The charge states will be synchronized
-  * No risk that the MPPT switches to float before the Multi does, and therefore backfeeding will stop
-Notes for systems where the Multi and the MPPT are not communicating (for example an MPPT 100/50 that does not have a VE.Can comm. port):
-  * Power can still be fed back to the grid!
-  * Set the absorption and float voltage of the MPPT slightly higher than the same set points in the Multi
-  * In a Lithium system, make sure that the MPPT can be switched off by the BMS.
-More information in the [[[[ve.can:ve.bus_to_ve.can_interface_manual|VE.Can to VE.Bus interface manual]].
 === What happens when there is to power to be fed back, but there is no grid available? === === What happens when there is to power to be fed back, but there is no grid available? ===
Line 56: Line 38:
 A maximum of 25 units can be connected in parallel. A maximum of 25 units can be connected in parallel.
 +===== DISQUS =====
 ~~DISQUS~~ ~~DISQUS~~
assistants/self_consumption_hub-1.1452267554.txt.gz · Last modified: 2016-01-08 16:39 by ictbeheer
