assistants:self_consumption_hub-1
| assistants:self_consumption_hub-1 [2014-08-03 12:33] – [More information] mvader | assistants:self_consumption_hub-1 [2019-01-22 09:16] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| ====== Self-consumption hub-1 ====== | ====== Self-consumption hub-1 ====== | ||
| - | ===== When to use the hub-1 Assistant? ===== | + | {{: |
| - | Use the Assistant for these systems with Solar chargers, ie. dc-coupled solar power: | ||
| - | * Grid that allows feed-back | ||
| - | * Grid that does not allow feed-back | ||
| - | * Grid + a backup generator | ||
| + | ===== When to use the hub-1 Assistant? ===== | ||
| - | Do not use this Assistant for the following | + | Use the Assistant for these systems |
| - | * No grid nor generator; solar only | + | |
| - | * Only a generator connected | + | |
| - | ===== More information ===== | + | Usage of all other policies of Hub-1 have been deprecated, in favor of [[ess: |
| - | See our [[http:// | + | Besides below information, |
| + | * [[https:// | ||
| + | * [[assistants: | ||
| ===== Frequently asked questions ===== | ===== Frequently asked questions ===== | ||
| - | ==== When is the grid used in Hub-1? ==== | ||
| - | * To feed energy back to the grid | + | === Do I need to use the VE.Bus |
| - | * To prevent inverter overload | + | |
| - | * For sustain (to prevent killing your battery) | + | |
| - | * To make sure equalize is finished (once every 28 days) | + | |
| - | ==== Do I need to connect the Multi or Quattro to the MPPT with VE.Can? ==== | + | No, not anymore since CCGX v1.73. See [[https:// |
| - | The advantages of using the VE.Bus to VE.Can interface are: | + | === What happens when there is to power to be fed back, but there is no grid available? === |
| - | * The MPPT will automatically use the settings from the Multi, no need to configure the MPPT. | + | |
| - | * Equalize is managed by the Multi | + | |
| - | * The charge states will be synchronized | + | |
| - | Notes for systems where the Multi and the MPPT are not communicating (for example an MPPT 100/50 that does not have a VE.Can comm. port): | + | |
| - | * Power can still be fed back to the grid! | + | |
| - | * Set the absorption and float voltage of the MPPT slightly higher than the same set points in the Multi | + | |
| - | * In a Lithium system, make sure that the MPPT can be switched off by the BMS. | + | |
| - | ==== What happens when there is to power to be fed back, but there is no grid available? | + | |
| The solar charger will charge the batteries until the absorption voltage is reached, and then reduces it's output. It switches to regulation on battery voltage instead of MPPT or output current. In other words: the batteries will not be overcharged. | The solar charger will charge the batteries until the absorption voltage is reached, and then reduces it's output. It switches to regulation on battery voltage instead of MPPT or output current. In other words: the batteries will not be overcharged. | ||
| - | ==== What happens when the battery is full and feeding back the grid is has not been enabled in the configuration? | + | === What happens when the battery is full and feeding back the grid is has not been enabled in the configuration? |
| See previous answer. | See previous answer. | ||
| + | === I do not have a Multi with the new microprocessor, | ||
| + | With older Multis and Quattros it is unfortunately not possible to feed power from DC back into the grid. It is possible to [[dc_coupling: | ||
| + | === How many MPPT 150|70 or 150|85 can be connected in parallel === | ||
| + | A maximum of 25 units can be connected in parallel. | ||
| + | ===== DISQUS ===== | ||
| + | ~~DISQUS~~ | ||
assistants/self_consumption_hub-1.1407069233.txt.gz · Last modified: by mvader
